Need help wiring genuine fog lamp switch and Hellas - Defender Source
Old May 21st, 2006, 10:14 AM
fleabus's Avatar
fleabus
Dan
None :(
For those of you who used the genuine fog lamp switch with aftermarket lights, how did you connect the leads from the switch?
I am using a switch like the one sold by Expedition Exchange, with some Hella 4000s and a Hella wiring harness.
Everything is as it should be... at least I think.
Yellow lead from light cut, lights grounded (brown), leads from lights to relay (blue), relay powered direct to battery (red), relay grounded direct to battery (brown), relay switch leads (green) to switch.
No worky
Thanks.
-Dan
Old May 21st, 2006, 02:00 PM
fleabus's Avatar
fleabus
Dan
None :(
Please disregard... I figured it out.
genuine, lamp, switch, wiring
Illuminated rocker switch source pmd Misc. Chit-Chat 7 March 9th, 2007 06:20 PM
hella wiring rover4x4 Defender Technical Discussions 13 September 11th, 2006 01:10 AM
Aux Rocker switch - OEM Kimos Defender Technical Discussions 3 December 1st, 2004 09:52 AM
Hella wiring problems... mlw911 Defender Technical Discussions 1 July 18th, 2004 05:06 PM
