Need help visualizing inner wing - Defender Source
Old April 4th, 2012, 04:06 PM
After months of deliberation, I've finally chosen what I think is the best spot for my onboard shower hookup when encamped. It's in my RH wing area. I'm going to get the external shower port from Adventure Trailer, which is flush when shower hose detached (as seen in stock photos below). A picture of my RH wing is below with the tentative location outlined by the yellow circle. What I can't visualize is what is between that spot and the inner wing that might obstruct the install. When mounted flush, the mixer valve needs some room for the hot and cold water lines to connect. Getting the lines up to that point is not an issue; I just need help with the few inches past the templated cut.
I plan on removing the headlight on that side to better assist with placement of the cutout, but any help in advance planning is appreciated.
ID:	49942   Click image for larger version
Name:	wing with cutout.jpg
Old April 4th, 2012, 04:19 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Here is looking in from the fender well into that very space. The backside of the bottom front marker light is seen for reference. Thinking you will have plenty of room. Fun project!
Old May 4th, 2012, 12:24 PM
Got it installed last night! I usually don't think twice about drilling holes in my body panels but I had to conjour up big BALLS to drill that 2" hole in my wing! What do they say? Measure 150 times and cut once?
There was in fact tons of room in there. I fed the water lines up in 1" holes drilled underneath the headlamp bucket and was easily able to pull them over to the mixer.
Tested system out and was quite please with results. The wing seems the perfect height for putting soap, towel and stuff on, and is well away from the exhaust should I need to keep engine running to keep the exchanger toasty hot for several people to shower. Next test is to see if Webasto can keep coolant hot enough for the exchanger without engine running.
ID:	51074   Click image for larger version
Old May 4th, 2012, 12:32 PM
Could be pretty near. What will you shower in? This pod over on the right?
http://www.defendersource.com/forum/.../2146/1148.jpg
Old May 4th, 2012, 12:44 PM
Yep, that's my pop-up shower tent. It self errects by itself with one of those springy frames.
That's an old pic. Good job finding that one!
http://www.hotcampshowers.com/inc/sdetail/379
Old May 4th, 2012, 12:46 PM
ha it's in your registry!
Old May 4th, 2012, 12:48 PM
Dang. I need to upload more in there. Thanks!
wing
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
Wing Vents mlw911 Defender Technical Discussions 17 June 28th, 2004 11:26 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 12:56 PM
Mounting wing top protectors Chaucer Misc. Chit-Chat 5 March 10th, 2004 07:34 AM
For sale: Daimond Plate Half Wing Protectors Burke For Sale - Parts 0 January 25th, 2004 11:20 AM
