Need help swapping lock barrel on RoW rear door - Defender Source
Old April 7th, 2014, 09:27 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I am trying to remove the lock barrel from the old door latch on my rear door, so I can install it in the new latch. I called Brian at Defenders NW, and he told me there is a small hole with a button to depress which would release the barrel. I have tried putting small objects in the hole & broddling around, but the barrel won't release. There are two indents that line up, and one hole- I am trying with the holes lined up. I have tried with the key in and out, and shot a bunch of oil down in there, no dice.
Any suggestions?
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old April 7th, 2014, 09:45 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Are you twisting the barrel once you depress the pin?
MUDSUX
Old April 7th, 2014, 09:46 PM
richord
Richard Ordowich
1987/D90
I tried to remove my barrel but it would not budge. I drilled mine out.
Old April 7th, 2014, 10:23 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Yes. Tried it with & without key, no dice.
------ Follow up post added April 7th, 2014 07:23 PM ------
Where exactly did you drill?
Old April 7th, 2014, 11:54 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
If I remember correctly you have to put the key in and twist it slightly to line up the ball detent. Once lined up push the pin in and pull on the key...i had to drill mine and ended up breaking part of the lock mechanism. I was able to split the latch open and repair it however.
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 8th, 2014, 12:09 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
What is the part number for a new lock barrel?
I managed to get the old one out (tore the whole assembly apart) but the barrel won't fit the new latch, no matter how I try it.
Thanks in advance,
Paul.
Old April 8th, 2014, 12:14 AM
Greg S
Greg Sutfin
1986 90
Looks to me that your tool is to large for the hole. I haven't taken that lock barrel apart, but, usually there is one of two scenarios.
1. Insert a working key! Insert a prob that easily fits in the release hole and depress the retainer. While holding the retainer in, slowly pull the cylinder (barrel) out. A working key is needed to do this. Lots of dirt could have made it difficult to depress the retainer so make sure it is well flushed out with WD40 or similar.
2. Same as above but you might have to rotate the cylinder to get the retainer to line up with the probe hole. Once the retainer is lined up and depressed, pull the cylinder straight out without rotating it.
Before doing either of the above make sure there isn't a latch pinned to the back of the cylinder like on the back door of a 2A where the hook is the lock.
------ Follow up post added April 7th, 2014 09:17 PM ------
Guess my reply is too late. Better picture now showing no latch attached to the back.
Good luck!
Old April 8th, 2014, 07:57 AM
richord
Richard Ordowich
1987/D90
I drilled through the front of the lock where the key goes in. I started with a smaller drill like a 1/4" and then slightly larger drill. You only want to drill to slightly less than the key depth when inserted in the lock. The lock will fall apart and not damage the sleeve. Pull out the old parts and inset the new barrel.
In my case after all that work I realized the whole door latch had seen better days and I replaced it!
Old April 8th, 2014, 08:36 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Turns out the old barrel didn't have a detent release pin after all.
Ordering a new set of locks today...
Paul.
Old April 8th, 2014, 12:44 PM
remember that the old style rear door latch lock barrel is not the same as the old style front door latch lock barrels.
Old April 8th, 2014, 01:20 PM
From what I understand from the pictures....he has purchased the newer style latches and was trying to move the barrel(s) over....
The newer latch style is a lot better.
Old April 8th, 2014, 03:10 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Correct. Ordered a set of 3 barrels with 2 keys today. It will be nice having one key for all 3 locks instead of 3 keys for 3 locks!
Paul.
door, rear door
NIB Lock Barrel sets with keys Abrooks For Sale - Parts 8 June 30th, 2013 05:42 PM
Pressed doors ( TD5 / Puma ) lock barrel? leastonce Defender Technical Discussions 3 February 8th, 2013 02:27 PM
lock barrel / cylinder One Ten Wanted 0 February 22nd, 2012 09:19 AM
Glock 19 Threaded Barrel -Light -mag Rugbier The Flea Market 2 July 8th, 2010 01:56 PM
