Need help replacing headlamp panels please. - Defender Source
Old July 15th, 2009, 01:24 PM
mgdpublic
M D
1997 Defender 90
I have a 1997 defender 90 and have to replace the thin plastic panels surrounding the headlamps. I've taken off the orange and yellow lamp and the bottom lamp (the larger one) has two screws keeping on the circular mount. I've tried to unscrew them but they have some sort of plastic collar on the inside which keeps them from unscrewing all the way. I can't fit anything in the whole to anchor the collar while I unscrew it. Anyone know what I'm talking about here and know what I can do to get these screws out? I've also run into the same problem with the screws holding the side mirrors on but I can't see what's stopping the screw from coming out. Thanks in advance,
MGD
Old July 15th, 2009, 03:31 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
They are called "nutserts" and it is common that they will spin when the truck gets older and a little corrosion happens between the screw and the nutsert. When they spin you have to hold the back of them, or drill/ grind off the screw head. Then replace them.
They suck however so a better way is to file the hole out square and put a RTC3744 plastic nutsert in and use a screw. That way, with no nutsert, the screw can never get stuck again during future services.
Side marker lights have them too and they are famous for sticking and/or spinning.
On the side mirrors they have a black plastic bushing on the screw that keeps them from backing off. Once you have the mirror off you can tap out the screws and you'll see the bushing.
Email:
Old July 16th, 2009, 07:13 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I am giving well-nuts with button hex drive stainless machine screws a try, good antivibration properties and no need to over-tighten to get a secure hold. Will report once I have things worked out (still waiting for a huge shipment to start re-assembly)
ac, lamp, panels
Black Friday Special - Stainless steel door panels LenB For Sale - Parts 18 December 23rd, 2006 11:56 AM
ST door panels neo812 Wanted 0 June 12th, 2005 03:50 PM
Replacing 4.0 with 4.6 Trevor Tarr Defender Technical Discussions 17 December 15th, 2004 10:21 PM
looking for advice on replacing the rear seat Doug Young Defender Technical Discussions 7 December 11th, 2004 05:40 PM
FS: Handmade cedar wooden top + interior panels (or trade..) jaherring For Sale - Parts 5 August 25th, 2004 07:21 PM
