Need Help Quick!!! Ignition Problem... - Defender Source
Old June 18th, 2008, 09:46 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Well my D90 is in the paint shop and they called this morning and said that they are turning the key but nothing is happening and the steering wheel won't unlock. Has anyone ever run into this before? Any help would be great.
Old June 18th, 2008, 10:27 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Not sure but I think my steering wheel locked once and I had to sort of rock it (the steering wheel) back and forth till the key would turn or turn it one way or the other sort of forcefully till the key turned. It seems like its a steering wheel locking mechanism that gets stuck.
Hope that helps.
Old June 18th, 2008, 11:03 AM
bitz's Avatar
bitz
Jon
Thanks but the guy told me that the key is turning no problem but the steering wheel still won't unlock. Wierd huh? I'm going over there at lunch time to try and help him look at it.
Old June 18th, 2008, 01:06 PM
bitz's Avatar
bitz
Jon
Well I ended up just pulling the hole ignition out so that there is no lock and you can start it with a screw driver. Guess I'll have to rip this thing open and see what's going on inside.
Old June 18th, 2008, 08:01 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Had that happen to mine, may have snapped a shaft inside the lock.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 23rd, 2008, 05:44 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Get a new lock thats' my top tip.
I ran with a dodgy steering lock/ignition switch for a long while, then one day I was tootling along, turned the wheel for a bend and the steering lock locked on without driver input. That made for a white knuckle emergency stop. the people coming the other way were a bit startled too
Mike Hammond
Starter, or Ignition Problem????? RickM Defender Technical Discussions 2 July 14th, 2008 02:06 PM
Ignition Problem Dfndr90 Defender Technical Discussions 1 November 21st, 2004 08:26 PM
ignition problem Irish1 Defender Technical Discussions 4 July 24th, 2004 09:41 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
