Need help... no spark - Defender Source
Old January 2nd, 2016, 01:14 PM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
Wish i knew more about this but i don't. Had my coil and ignition module replaced in July (mallory coil) and all of a sudden, I'm getting no spark. any suggestions would be great!
'94 D90 "HAL" & 96 Disco "Narlee"
Old January 2nd, 2016, 04:58 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Subscribed.
Old January 2nd, 2016, 05:02 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
What precipitated this no spark condition? Are you getting fuel (do you hear hear the fuel pump whine when you turn the key) or is that out too?
What motor is this?
Old January 2nd, 2016, 05:52 PM
How did you test no spark?
do you get a single spark and nothing or nothing at all?
Old January 5th, 2016, 08:31 AM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
What motor is this?
i'd had trouble with the fuel pump so I'd put in a new one last july along with a Mallory coil and new ignition module. ran fine since then. then it began not starting just a couple weeks ago. the fuel pump whir's when i turn the key and i hear the relay up in the dash click after a few seconds and the fuel pump turns off. i think thats normal? as for the spark test, I'd pulled the wire off one of the plugs and held it right next to the plug and saw no spark. to avoid taking out the plug, i bought another and tonight and going to connect one of the existing wires to this new plug and lay it near the block to see if the bottom sparks. thought i'd get the correct result holding the wire near the existing plug but i'm getting conflicting messages from people saying I need to try it both ways. one as i have, and the other on a separate plug laying it near the block to see if it fires.
Old January 5th, 2016, 09:01 AM
There are white wires that connect the coil. All white is from IGN module to coil +. There is a white/black that sends SPK OUT sig to the ECU. Sometimes these (old brittle) wires break right at the spade connector. Worse, they are holding on by one or two strands and are about to go.
I would look at the connections first and see if any have failed.
If they are good, then the next thing will be to look at the module. Do you have the old one you can use temporarily?
Old January 5th, 2016, 09:17 AM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
Thanks Bill.. i'll check those wires too. No, i don't have an old module to use. Carlos threw the new one on for me so i didn't keep my old one.
Old January 5th, 2016, 09:37 AM
Do you have the Mallory distributor? There is a specific test they outline using a credit card and a voltmeter to check the ignition module function. Do you also have the prescribed resistor(s), etc. for the system you're running?
http://www.defendersource.com/forum/...mly-65104.html
http://www.defendersource.com/forum/...own-65155.html
http://www.defendersource.com/forum/...rts-20662.html
http://www.defendersource.com/forum/...irm-55302.html
http://www.defendersource.com/forum/...art-36737.html
http://www.defendersource.com/forum/...nue-49449.html
http://www.defendersource.com/forum/...ast-29056.html
Spark Plugs?? Please help. Spenc1tj Defender Technical Discussions 7 May 16th, 2015 11:25 AM
Good Spark, Bad Spark Big D Defender Technical Discussions 4 August 19th, 2008 09:43 AM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
Spark plugs for a supercharged 4.0.. Tom Fitzgerald Defender Technical Discussions 0 May 10th, 2004 11:43 PM
Spark Plug Poll DJ Menasco Defender Technical Discussions 5 March 17th, 2004 07:12 AM
