need help making holes in fenders for front cage - Defender Source
Old April 18th, 2010, 01:35 AM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
Purchase fenders, blank, no holes for lights nor for cage support pillars.
What is the best way to make holes?
Anybody has pre made shapes to help to do that? Any suggestions how to not bend it, while drilling and cutting?
------ Follow up post added April 18th, 2010 02:05 AM ------
found the link
//www.roverworld.com/rollbar_english2.htm
Anybody has template?
Old April 18th, 2010, 05:32 AM
You don't have the old fender for measurements? I don't have template, but the basic approach is to cover the area with masking tape, then draw your opening onto the tape. Start drilling small holes and work up to a larger bit so that when you are done you have radiused corners for your opening. Then just connect the holes by cutting with a dremel tool or similar. Then just finish up with a fine file.
Old April 18th, 2010, 07:43 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Like Jim says... make template.... mask the area, drill corners. maybe a3/8 drill.. I then use a 2" cutoff wheel and cut between and you are done.. take about 15min..
I think the front marker light hole on the 94 you can use a hole saw..
Legend in My Own Mind.
Old April 18th, 2010, 11:30 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Measure twice, cut once.
- Charles Eames
Old April 18th, 2010, 01:43 PM
pendy's Avatar
pendy
jim pendleton
89'd90
The masking tape really helps.
legend in my own mind
Old April 18th, 2010, 01:48 PM
madcowdungbeetle
Carter
To expand on this a little bit.
Make sure its a fresh and true hole saw, and absolutely use a solid backing.
Old April 18th, 2010, 11:49 PM
CDeWan
Clay DeWan
5.3L beastie
You can always go with a dremmel cutting wheel and go slow.
cage
Randy's Roll Cage AlanB Smaller Projects 12 June 12th, 2006 09:23 PM
Roll cage inner fender braces Method PHX Wanted 12 March 13th, 2006 12:08 PM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
Pickup cab and custom cage dave_lucas For Sale - Parts 11 January 7th, 2004 10:12 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
