Need Help Identifying Wire (Photo) - Defender Source
Old April 29th, 2006, 02:15 PM
fleabus's Avatar
fleabus
Dan
None :(
While crawling around under the truck this morning, I noticed a loose connector above the xfer case.
What is it?
Should it be plugged into anything?
Thanks.
-Dan
Old April 29th, 2006, 05:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
is that a red wire with a black stripe or two wires?
Old April 29th, 2006, 06:14 PM
Yeah, need to know the exact colors.
Old April 29th, 2006, 06:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
That might be for the E brake light..
Legend in My Own Mind.
Old April 29th, 2006, 06:29 PM
fleabus's Avatar
fleabus
Dan
None :(
2 wires...
  • 1 black
  • 1 grey w/ red stripe
Thanks again!
-Dan
Old April 29th, 2006, 10:09 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
here ya go:
first wire
s=stripe color(slate grey)
r=main wire color
second wire
b=black
jeff
Old April 29th, 2006, 10:27 PM
fleabus's Avatar
fleabus
Dan
None :(
Originally Posted by 48vphantom
here ya go:
first wire
r=main wire color
second wire
b=black
jeff
Imagine that... thanks Jeff!
-Dan
Old April 30th, 2006, 12:04 AM
artm
Arthur Maravelis
97 SW
Not so fast...
In a 2000 model year owner's manual for Defender 90/110/130 Td5/Tdi/V8 there is listed a trans oil temp warning light as an optional fitting. The electrical manual says this connector C218 is involved, as per the pics.
So, I wonder if a temp sensor can readily be fitted to the ZF?
ID:	5596   Click image for larger version
Old April 30th, 2006, 04:41 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
hall effect probe for speedo sender fitted to later vehicles
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
photo sizes - how to reduce paulb Support & Suggestions 2 November 26th, 2003 05:12 PM
