Need help identifying a leak..... - Defender Source
Old October 7th, 2013, 08:14 PM
bradleyt09
Brad Taylor
'97 D90 ST
For the last two days, I've noticed a lot of "oily" yellow fluid dripping from underneath just about four inches from the inside of the right front tire. No foul smell and fluid has an oily feel to touch. Significant amount of fluid so just wondering if it's OK to drive an hour to Rover mechanic or may I do damage driving this far with the leak I've described?
Old October 7th, 2013, 08:24 PM
Really need to know what engine you have and if you are right or left hand drive to help
Mark Kellgren
KM4BOR
Old October 7th, 2013, 08:26 PM
Its probably a NAS D90...
Old October 7th, 2013, 08:27 PM
C391HAT's Avatar
C391HAT
Zach
86 110
Not sure the difference between a RHD ROW truck and NAS but that's where mine leaks its power steering fluid
Old October 7th, 2013, 08:29 PM
If it is a NAS truck its probably just has an infection in the stub axle
Old October 7th, 2013, 08:34 PM
bradleyt09
Brad Taylor
'97 D90 ST
It's a '97 NAS D90. My main concern is whether it can be driven for an hour to the shop without damage?
Old October 7th, 2013, 08:40 PM
It depends on what is leaking. Its probably engine oil which is easy enough to check, or a leak from the axle. Have you had your oil changed lately? It could just be a loose oil filter.
Old October 7th, 2013, 08:46 PM
bradleyt09
Brad Taylor
'97 D90 ST
I haven't change oil lately. I bought the truck about a year ago - oil was changed just before I bought it and approximately 2-3K miles ago. Dip stick reads full. Just the other day, I was commenting how dry this truck is underneath. I cursed myself by speaking too soon.
Old October 7th, 2013, 08:47 PM
Its probably your front axle leaking somewhere then. Depending on how much it is leak you'll probably be fine.
Old October 7th, 2013, 11:33 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Brad throw up a couple of photos of the problem...
Old October 8th, 2013, 07:33 AM
bradleyt09
Brad Taylor
'97 D90 ST
I cleaned up the leak last night. There was a lot of fluid puddled a few inches inside the front right wheel of the vehicle, flowing down the grade of the garage floor (so the fluid was relatively low viscosity, like oil). I have not driven the truck since last night. I shot some iphone pics this morning and there is only a very small spot on the floor so it leaks much more after driving. The only "wet" spot below the vehicle is pictured below. Also, the spot on the ground is forward of the front passenger wheel today. It must have been leaking much heavier yesterday so that it was hitting the ground and then splashing back toward the tire. Any help?
Name:	photo 4 (2).JPG
Name:	photo 2 (4).JPG
Name:	photo 3 (2).JPG
Old October 8th, 2013, 07:45 AM
Power steering fluid? Can't think of anything else that far forward.
Old October 8th, 2013, 08:01 AM
Looks like antifreeze to me. I cant think of anything else that splatters like that when it drips.
Old October 8th, 2013, 08:20 AM
Bill Larson
Bill Larson
yeah those photos don't say much...can you tell where it might be coming from? don't clean it then take photos...also of where its pooling on the ground.
Old October 8th, 2013, 08:40 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Looks like coolant to me as well.
Does it smell sweet?
Old October 8th, 2013, 09:23 AM
bradleyt09
Brad Taylor
'97 D90 ST
No smell at all. Definitely an oily consistency. No overheating and engine temp is OK.
Old October 8th, 2013, 09:35 AM
Bill Larson
Bill Larson
what does it taste like on a cracker? lol...
Old October 8th, 2013, 09:38 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
could be a small leak in one of your coolant hoses. Cant imagine what else would be that color. If you have pets keep them out of the garage, cats love antifreeze, but it kills them
Old October 8th, 2013, 09:43 AM
That's coolant. Look upstream - around the radiator and then follow the hoses coming from it. There is a larger hose coming out of the bottom of the radiator on the passenger side, which has a smaller tube coming off of it going to the reservoir (also on the passenger side). You should be able to trace the leak uphill to the source. If it's too messy, wash off the area, let it dry, then go for a test drive checking periodically and you will find the leak.
Until you know what's leaking it's hard to tell if a hour long drive would be a problem or not.
Originally Posted by pendy
I'm here for the D's
Old October 8th, 2013, 10:35 AM
Dexcool, what color is the radiator fluid?
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
