Need help identifying a leak..... - Page 2 - Defender Source
Old October 8th, 2013, 10:44 AM
you can buy coolant dye and a blacklight from autozone. add it to coolant, then check with blacklight to find the illuminated coolant leak a day later.
the only other thing that far forward is going to be your AC condensor. I'm not sure what it would look like if you had a coupling leak, but there's oil in the refrigerant.
Mark Kellgren
KM4BOR
Old October 8th, 2013, 10:45 AM
Isn't it possible that it's coolant overflow?
Old October 8th, 2013, 11:04 AM
bradleyt09
Brad Taylor
'97 D90 ST
What an awesome forum. Thanks to everyone who chimed in. I believe this is a coolant leak and will have the mechanic check it out. It's due for service anyway so she'll get a clean bill of health. I really appreciate all the input and will update as soon as the mechanic confirms the source of the leak.
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
