Need Help Diagnosing Odd Sound - Defender Source
Old May 18th, 2009, 04:31 PM
fleabus's Avatar
fleabus
Dan
None :(
Ok... 97 (auto) runs/drives/shifts great.
Once the engine warms up, I stop completely, put it in reverse and can hear a subtle grinding/gravelly sound... almost like a loose heat shield rattling. The noise occurs when stopped... as soon as I start moving, I can't hear the noise again. I have not observed the noise when the engine is cold.
I have checked underneath, but can't pinpoint the origin (no loose heat shields). Seems to only happen when in reverse, but have on only a few occasions noticed the noise when stopped and in drive.... trans/xfer case?
Mechanic is taking a look later this week, but thought I'd check with the pros first
Cheers!
-Dan
Old May 18th, 2009, 05:17 PM
Sounds like a bad cat? Marbles in a can? Stops when the rpms start to climb. Does it only at idle?
Old May 18th, 2009, 05:25 PM
fleabus's Avatar
fleabus
Dan
None :(
Maybe... except I replaced the cats/y-pipe only about 1-2 years ago. Less marbles in can and more like gargling gravel when in gear (reverse), but silent in neutral.
Old May 18th, 2009, 06:06 PM
Not sure. Try to isolate the sound. Sometimes the pump in the transmission makes a noise like that. It would be about all that would be spinning in that situation.
Old May 18th, 2009, 08:16 PM
low on fluid then?
Old May 18th, 2009, 09:46 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
Try checking your exhaust and tighten all the bolts connecting your muffler to your cats and your tail pipe . My vehicle makes these noises after a good offroad pounding and all it takes is the above to fix it .
Old November 22nd, 2009, 11:16 PM
fleabus's Avatar
fleabus
Dan
None :(
Follow-up post: When the truck warmed up... the passenger side cat was just barely touching the frame which created the noise I was hearing. Readjusted and re-tightened everything and it is all better... thanks for all the tips!
-D
does this sound like a rover V8 rover4x4 Misc. Chit-Chat 4 January 5th, 2006 06:24 PM
Sound Dampening Material kellymoe Misc. Chit-Chat 1 March 13th, 2005 01:34 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
