Need expected 2.8 TGV compression PSI - Defender Source
Old July 24th, 2015, 03:49 PM
manual doesn't provide targets or ranges for compression tests. anybody know what would be the range for a healthy engine?
Mark Kellgren
KM4BOR
Old July 24th, 2015, 04:11 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
I'm under the impression its 19.5:1.
Black Rhino Lives Matter
Old July 24th, 2015, 04:19 PM
yes, but what's the translation to psi for reading off the gauge?
Mark Kellgren
KM4BOR
Old July 24th, 2015, 04:23 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Hope this will help.
https://xa.yimg.com/df/hs2800TDI/Eng...&type=download
Old July 24th, 2015, 04:28 PM
disregard. I found the calculation, thanks.
Mark Kellgren
KM4BOR
Old July 24th, 2015, 04:48 PM
350psi plus. 340ish is the min to get diesel to combust
Old July 24th, 2015, 05:08 PM
hmm. at 29.96 in and 19.5 ratio, the calculation came out to 286 psi. the shop that has my truck did a compression test on mine, and it came back 250-290 psi on all cylinders. and the truck drives fine (albeit that pesky turbo seal that failed after being rebuilt in Feb. ).
I'm assuming the calculation and test were not done correctly?
29.96in=14.71 psi
(14.71*19.5)/1 = 286.84psi
Mark Kellgren
KM4BOR
Old July 24th, 2015, 05:22 PM
shop thinks it was the compression gauge. they had trouble with the quick disconnect so assume reading were off. where did I go wrong in the calculation though?
Mark Kellgren
KM4BOR
Old July 28th, 2015, 03:22 PM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
If it's of any value I just did a compression test on my 200tdi and I have 460 to 480 across the cylinders with cold engine. I bought a $39 tester on harbor freight that I tested withy air compressor at 150psi and it reads fine. First pump is 160 to 180 on all 4. I put a few squirts of oil in number 1 cylinder and it read 500psi. We tested just one cylinder on my son's 2.5 NA hot and it reads 500. Isn't all this too high?
Old July 28th, 2015, 03:24 PM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
A photo
Old July 29th, 2015, 06:04 AM
Too high?❓
Old July 29th, 2015, 08:50 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Too high?❓
The compression figures I see on the web regarding 200/300tdi are much lower. I've read that too high could mean carbon buildup?
Old August 1st, 2015, 07:31 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
350 psi min. Also important that they should all be very close to the same across all cyl.
------ Follow up post added August 1st, 2015 07:32 AM ------
Never had one suffer from too high a compression…..unless it had water in it.
Matt Browne
Old August 1st, 2015, 11:11 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Never had one suffer from too high a compressionů..unless it had water in it.
Great than!
Suggested PSI for driving on sand? ditskovich Defender Technical Discussions 6 May 31st, 2011 02:35 PM
90 Load Space Mats NOS expected on Friday SafariHP The Vendors Loft 11 January 26th, 2011 09:43 PM
Tata/LR/Jag announcement expected 3/26 Kev Baldwin Misc. Chit-Chat 0 March 25th, 2008 07:53 PM
power bleeder psi D90user Defender Technical Discussions 1 October 5th, 2006 11:29 PM
Fuel Pump running PSI and deadhead PSI? RedRhinoProducts Defender Technical Discussions 0 February 27th, 2005 02:35 PM
» Defender Registry
"Harry"
lousapienza
248
xjahx
Add your Defender
