Need Brake Servo Check Valve - Defender Source
Old October 14th, 2013, 02:21 PM
CDeWan
Clay DeWan
5.3L beastie
O.k. kinda weird. I have my check valve on my plate below the plennum tapped into one of the 3 spaces where you can put something that needs vacume. At my servo I have a 90 degree T. Looking to find these parts..and numbers anyone running this set up? I called the usual suspects and it appears that the listing that they have is for a check valve at the servo and not at the plennum so a seperate set up then mine.
Help...if anyone knows the Napa part numbers that would be great.
Old October 14th, 2013, 03:30 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Does your set up look like this one... http://www.rimmerbros.co.uk/Item--i-GRID010539
Might be a starting place???
brake
Clutch master - brake servo or fender wing removal ? JFD Defender Technical Discussions 14 November 20th, 2012 06:03 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
