Need ARB locker install manual - Defender Source
Old June 14th, 2004, 11:15 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Post Need ARB locker install manual
Does anyone have an extra ARB air locker install manual that they can scan or send me?
I just picked up a 2 that did not come with the manual and I would like to make sure I wire them correctly.
Dave
Old June 14th, 2004, 12:08 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Here ya go!
http://www.dynamics.co.uk/landrover/...e%20Manual.pdf
Good luck with the install!
DJ
Edit
Oops. Sorry, that was only the operating manual.
DJ
Old January 6th, 2006, 09:15 AM
vianna_andre
aNDRE/vIANNA
I don't download from http://www.dynamics.co.uk/landrover...%20M anual.pdf
Andre
Old January 6th, 2006, 01:50 PM
Tdi Lurker
Big Gord
1971 IIA 88
Dave
i should have what you need ......is it the rover diff or the salisbury one you need......give me an address and i will see what i can find....
Big Gord
Old December 4th, 2006, 07:05 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Big Gord
I would love the manual to install an ARB locket in for the front diff of my '95 D90. That's a rover diff I believe.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 09:33 AM
http://www.defendersource.com/tech/arb.html
Old December 5th, 2006, 09:51 AM
Tdi Lurker
Big Gord
1971 IIA 88
Sorry mine are long gone....or at least very well hid since my move to my new shop
Gord
Old December 5th, 2006, 10:24 AM
MonLand
Loic Fabro
Originally Posted by evilfij
Yep, I saw this. But the "front ARB install" part is still not updated! ;-)
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 10:30 AM
It is the same as the rear. Just pull the axles out and pull the pumpkin. You just need circlip pliars to get the drive flange off the cv. If you can't get the pumpkin out I would not consider trying to set up an ARB.
Old December 5th, 2006, 02:29 PM
btate
Bryan Tate
d90
Do you need directions for the compressor wiring or the ARB install?
Old December 5th, 2006, 02:38 PM
MonLand
Loic Fabro
I take that question for me then! :-)
- ARB install: the official install guide or anything beyond what is described on the D-90 Tech section would be nice
- the ARB compressor is already installed (rear locker in place and working), so unless there is anything I need to know about the wiring, I should be all set (electricity and air stuff I can manage! :-) ). I did read that "by default" the front locker can not be engaged if the rear locker is not.... I assume that is only true if you use the arb wiring harness/kit. (and I guess it is because the 12V that comes from the rear locker relay is also the 12V used as the input for the front locker relay.... In which case, bring in a 12V directly to the front locker relay would be extremely easy).
However, if you have leads on how to get cheap solenoid for the air setup that would work with the stock (?) ARB setup, that would be cool! I actually did not open the ARB locker box yet.... I have no idea what's in it (beside the locker itself).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 5th, 2006, 03:39 PM
btate
Bryan Tate
d90
I just had GBR put mine in the 3rds, I have the manual for the compressor wiring. But, didn't see any other manuals.
What about asking Bill at GBR for a fax on the instructions?
Old December 5th, 2006, 04:33 PM
MonLand
Loic Fabro
Well... I got my locker from ARB directly (long story short, won a discount coupon that made it cheaper than reseller can get... locker has been in the box for the last three years now....), so I don't think it would be fair for me to ask Bill for the instructions..... [But I can provide you with a fax number if you want to call him! :-)]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 6th, 2006, 11:05 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
The ARB Locker install manual does not have any instructions on how to set up the diff assembly. It states to refer to the Land Rover Service Manual for installation.
The ARB Manual shows how to run the Air Lines, Tap the Case, Install the Banjo Air Fitting, etc.
I could copy the manual and fax it to you if you need it, but be forwarned it does not cover diff set up!
--Benjamin Franklin
manual
Manual Diff Locks and ARB Locker snurp Defender Technical Discussions 4 May 28th, 2008 10:24 AM
ARB locker install problem... Heath Defender Technical Discussions 10 January 12th, 2007 08:35 PM
Arb Locker Tech Manual (.pdf) online, courtesy of ARB USA Cube II Misc. Chit-Chat 4 December 5th, 2006 04:28 PM
Rear ARB Locker RickM Defender Technical Discussions 4 April 20th, 2005 12:22 PM
ARB locker TwisteD90 Defender Technical Discussions 2 December 2nd, 2003 11:26 AM
