need alternative light bases - Defender Source
Old July 31st, 2013, 10:59 AM
Finished testing the entire wiring harness for my truck ex-situ prior to install. Everything works but the cheap Series plastic light bases are literally melting under the heat of the 1156/1157 bulbs.
Looking for alternatives, I found full-up LED replacements for $300 from Bolt on Bits and Powerful UK Ltd.
The other alternative is DA1080 which are 300tdi light bases, about $45 from Trevor.
Does anyone use the 300tdi DA1080 light bases? Do they melt under the heat of 1156/1157 bulbs? Are these older light bases all junk and should I go straight to dedicated LED?
What kind of connector do the DA0180 light bases use?
Thanks!
Old July 31st, 2013, 11:03 AM
Ed I am interested in this too. Would like to go all LED but retain the same exterior look on my IIA project.
Originally Posted by pendy
I'm here for the D's
Old July 31st, 2013, 11:13 AM
Charles,
http://www.ebay.com/itm/8-RDX-LED-ST...item5aee113bf6
These seem like the most cost effective so far. At $215 shipped, it is essentially $26 / light, which is cheaper than the cost of bases + bulbs.
http://www.ebay.com/itm/8-RDX-ALL-CL...item35c3ec48fe
These are slightly more expensive but are "all clear" as opposed to colored.
Old August 5th, 2013, 10:13 AM
Does anyone have any reviews of or experiences with the boltonbits Ebay RDX LED lights?
Collin? I know you have a set up for sale, perhaps you have an idea of how well they perform?
Old August 5th, 2013, 10:32 AM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
i have done a set on amity90's truck and there very well made and has factory connectors , the resisted relay works very well when dialed in
No Mall crawler here
Old August 5th, 2013, 11:31 AM
thanks much, Chris.
Old August 5th, 2013, 11:33 AM
Does anyone know what the differences are to make it fit a 2a? The listing says it works for a series 3 but would need mods for a 2a
Old August 5th, 2013, 01:08 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Very strange. I've never had a series lens melt except when I used halogen bulbs.
In any case, aren't the 56/57 base LED bulbs so you don't have to replace your entire housing?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 5th, 2013, 02:12 PM
Hey tom, not the lens itself, but the base (the white plastic that holds the bulb against the contacts). The heat of the bulb actually melts the bayonet base causing the bulb to "slip out" of the bayonet.
Yes, the 1156/1157 base LED bulbs allow the use of old bases, but my reasoning is that if the RDX one-piece LEDs are good, then the total cost for 8 lights (and reliability) is better than retrofitting for 1156/57-base LEDs.
Old August 6th, 2013, 05:22 AM
Antichrist's Avatar
Antichrist
Tom Rowe
that's equally strange, never had those melt either. If they melted I guess you have no choice but replace them, but I'd make sure you have clean contacts. It sounds like something, other than just the bulbs, is causing excessive heat.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 6th, 2013, 09:41 AM
I have had the same problem before.
Old August 9th, 2013, 11:38 AM
I have just received a full set of RDX LED lamps from boltonbits. (red brake, clear indicators, clear running lights). Quality seems good, the units are completely sealed and ultrasonically welded.
I tested all lights and all are operational.
The brake lights and turn signals are very bright. The running lights are not as bright as I would like, but I would take dimmer lights that last over brighter lights that can lead to thermal degradation of the LEDs.
On-axis brightness is significantly higher than off-axis brightness. The lamps are less than 3W power draw each, meaning around 250mA.
I will post pictures as soon as they are installed.
Old August 12th, 2013, 08:01 AM
Height: ~1 5/16"
Diameter: ~ 2 7/8"
Mounting screw hole-to-hole spacing: ~2 1/8"
ID:	77494   Click image for larger version
Old August 12th, 2013, 11:15 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Law enforcement is starting to pay more attention to lighting.
You might want to consider returning the indicator lights and getting amber or red which are the only colors allowed per FMVSS 108.
They shouldn't charge you anything to exchange since they are sold you something that doesn't meet the Federal Motor Vehicle Safety Standard.
Same for the marker lamps.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 12th, 2013, 11:43 AM
Thanks guys. Correct, the leds are amber, the housing is clear.
I ran the same clear housing/amber bulb setup with the old knackered lamp bases.
Old August 12th, 2013, 12:13 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Yeah, that's true on clear lens/amber bulb. I wasn't "clear" on that from reading the post.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 12th, 2013, 01:12 PM
Good call, Tom. Can't be too careful!
Old August 19th, 2013, 10:17 AM
I installed and tested out the lights and they look fantastic. Very bright tailights, brake lights, turn signals.
The turn signals are indeed amber, but they are a "paler" shade of amber than typical yellow signals. It's actually rather pleasing aesthetically.
The sidelights (aka fogs) are the only slight disappointment: They are dimmer than I would like. I would have preferred Porsche-style blindingly bright LEDs, but these are less obtrusive. Still, they do the job.
Will take pictures tonight once the dash is back on, the wires are tucked away, and I can call the wiring of my truck complete.
Old August 26th, 2013, 09:36 AM
Pichers for Jeff
On-axis
Off-axis
Rear brake lights. Those are the brake lights in the "tail-lamp" setting. When the brakes are pushed, the brightness easily doubles.
The sidelights (the front white LED's on the top row) are barely visible in bright sunlight. They are really not particularly bright, but at dusk/night, they are ok.
ID:	78298   Click image for larger version
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
