Need Advice: Registering imported Defender in Denver, CO - Defender Source
Old February 6th, 2016, 01:25 PM
LRColorado
1990 Defender (200 TDI)
I recently imported a 1990 Defender from England.
Pre-purchase I spoke to Denver DMV Technical Center to find out the requirements to register the vehicle in Denver, CO. They told me that the vehicle needed to be original (engine, matching VIN, etc.) and that Port of Entry Customs (Houston) would need to stamp Form 7501 and Form 3461.
I worked with an Import Broker and they instructed Houston Customs to stamp these two forms. When the truck cleared customs they provided my Broker the stamped Form HS-7, but they did not stamp Form 7501 and Form 3461. The Broker sent via carrier the forms back to Houston Customs 3 times and called them. Houston Customs replied they cannot stamp the forms without having the truck in front of them.
So I have a vehicle that has cleared customs, a stamped Form HS-7, unstamped Form 7501, unstamped Form 3461, Form EPA 3520-1, and Customs API Activity document.
I called Denver Customs to see if they could stamp the docs since the are all part of the same organization and have access to Custom's Paperless System. I spoke to a Supervisor and he said since the truck came through Houston they can not stamp my paperwork.
I have an appointment this week with the Denver DMV Technical Center to get my vehicle inspected for registration and I am anticipating issues due to the incorrect forms being stamped.
I am not going to drive 2000 miles to be in the Houston Customs office for 30 seconds to get two pieces of paper stamped.
Not interested in the "would of" or "should of" comments.
Any useful suggestions on how to "work with" Denver DMV Technical Center to have a positive outcome when I go in this week?
Old February 6th, 2016, 03:51 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I would try to register it with just the one form stamped.
Old February 6th, 2016, 04:02 PM
RBBailey
RBBailey
1965 IIa
Yeah, see if it works to register it as is. Then go through the hoops.
If you worked with an agent, he should be the one taking care of this for you. I would think that his job is to see to it that these forms are stamped, his job is not done till they are. Am I expecting too much?
By the way, does the truck check out as original with good numbers and such?
Project:
1965 IIa SWB
Old February 6th, 2016, 04:07 PM
fruitpunch
Marc Brouwer
66 IIa 88 Perkins powered
This is why I advice against brokers at the end they don't care. I tried it once and the broker screwed up royally not worth it. In Newark they stamp everything including foreign reg, only pain in the neck is their expert. He pretends to know but is rather clueless in fact he tried to get me to say the wrong thing with his trick questions.
Old February 6th, 2016, 04:13 PM
phoenix37's Avatar
phoenix37
john
what were his "trick" questions?
Old February 6th, 2016, 04:16 PM
LRColorado
You are correct. When I spoke to Customs in Denver they said go back to your Broker they have to finish the job. I did and they tried one more time and apologized stating they have never run into this issue before. Customs and the Broker are very nice and sorry but I need action towards a solution.
Yes the truck checked out and was cleared after an intensive inspection. I think they had it for about a week.
advice, defender, import
Buying Defender 90 in CA and Registering in CO? connor016 Defender Technical Discussions 14 July 26th, 2015 12:33 PM
Registering a post-1997 Diesel in VA The Dro Misc. Chit-Chat 15 December 17th, 2010 08:16 AM
Registering a 1984 110 in California 1of40 Defender Technical Discussions 24 November 11th, 2010 12:18 AM
Experience registering a 1980's 200 tdi in CO aosias Defender Technical Discussions 4 December 14th, 2009 06:18 PM
Problems with registering chrisvonc Support & Suggestions 0 November 7th, 2003 10:36 AM
