Need advice on storing D90 - Defender Source
Old May 7th, 2004, 09:24 AM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
It looks like I might be out of the country for an extended period of time. What should I do to my truck to prepare for several months of non-use?
Old May 7th, 2004, 10:02 AM
Change fluids, put fluid stabilizer in the gas and disconnect the battery.
Old May 7th, 2004, 01:44 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Phil, I've left other vehicles for over 6 months simply by making sure all the fluids and gas tank were filled and disconnecting the battery. Tires will develop a flat spot from sitting all that while, but it goes away fairly quickly once you start driving again. You could put it on stands, but I don't think that (or other extensive prep) is necessary. I've also heard conflicting advice on whether you should have someone start it periodically, and just letting it sit never seemed to hurt anything on my other vehicle.
Old May 7th, 2004, 03:01 PM
PT94D90's Avatar
PT94D90
Phil
Thanks guys, I appreciate the info.
Old May 8th, 2004, 04:54 PM
nickt's Avatar
nickt
Nick Taylor
1998 Ex-Camel Trophy 110
Other than disconnecting the battery, I've never done any other prep when leaving mine for 6 months plus. Had no problems so far...
Nick.
Old May 8th, 2004, 11:54 PM
Cyborg
Larry Walton
'97 D-90 ST #2066 UK 4X4
On other vehicles that are carbureted I have heard of people pooring a little ATF into the carburetor while it is running. The idea was to lube up the cylinder walls well during storage. Of course you have a fuel injected engine so this may not be possible. I have also been told that after an engine has set for an extended period that it can be a good idea to pull the plugs and put some ATF into each plug hole before starting. Same basic idea. If it were me I would not do these things unless I were to be away from it for years.
Might want to contact your favorite professional mechanic.
Larry
Visit the Land Rover Beer Bar,"The Best Beer Bar X Far!"
90, d90
Advice on Winter Driving Preparation for my D90 advnirvana Defender Technical Discussions 10 December 4th, 2009 09:21 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
First Post Here - D90 Audio Wiring and Advice Kimos Defender Technical Discussions 3 October 12th, 2004 01:17 PM
D90 Advice: mlw911 Defender Technical Discussions 7 May 9th, 2004 06:51 PM
