Need a transfer case - Defender Source
Old January 18th, 2012, 05:49 PM
icurnmedic
Thomas Church
1994 Red D90
OK, to throw it out there, I know nothing about vehicles, much less a transfer case. There isnt a Land Rover Dealer less than 2 hours away, and my mechanic, is good, but new at the rover thing. So, what I do know , is he says my 1994 D90 needs a T-case, but doesnt know how to go about getting one... What Im asking is , anyone know where one can be bought? What about rebuilt? Crossover from Discovery? Obviously, I want to go the least inexpensive route to get the job done, but not so worried about price as, effectiveness. As always thanks for the input, Thomas
Old January 18th, 2012, 08:13 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Will Tillery should have used ones for a good price, and I think he guarantees them.. Plus, he's in Danville.. call him up and see.
-Ren Ching
Old January 18th, 2012, 08:15 PM
I have a spare you can borrow with about 50K on the clock.
Old January 18th, 2012, 08:34 PM
I've got two. They are cheap and readily available. Paul Grant on discoweb has them, I know Will just got a DI in so give him a call. A DII box will have CDL 99,00,04 but you will have to swap the rear section for the speedometer drive.
Why does your mechanic that knows nothing about rovers assume you need a new transfer case, I am betting its the gearbox.
Old January 18th, 2012, 09:03 PM
They are a snap to rebuild. I did it without a press, so having one would be even easier.
Old January 18th, 2012, 09:06 PM
Why if you can get one for 200
Old January 22nd, 2012, 04:52 PM
piper109
Steve
1999 Disco 1 SD w/300tdi
I have one I can sell you. It came off a 96 Disco tdi and was mated to an R360. As far as I know, it had 156k on it. It came off a good running truck and I am still using the engine and gearbox it was mated to.
I replaced the seals on it but I decided to re-use the one on my 99SD when I did the diesel swap.
Its in Columbia SC at present but I basically live in Ashe County, just up the road from you...so I could bring it up easily enough.
Steve
transfer case
transfer case questions HELP! mattwhite Defender Technical Discussions 2 March 8th, 2009 02:45 PM
Transfer case output nut size? Trigger Defender Technical Discussions 5 April 12th, 2005 03:32 PM
94 transfer case problems Campbell Defender Technical Discussions 25 March 19th, 2005 12:09 PM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
