Need a new radio for my '97 NAS D90, what is the consensus choice? - Defender Source
Old October 2nd, 2015, 09:14 AM
dendrite's Avatar
dendrite
97/D90 #147
Previous owner installed a Sony head unit that works, but has the typical disco lights, equalizer bars, and tiny buttons that I hate.
I'd like to find a unit that has bluetooth, and simple, more industrial looking faceplate. Yes, I know the noise level in the truck is not conducive to high quality listening, but I do want it for taking phone calls and streaming Pandora. ?
Old October 2nd, 2015, 09:35 AM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
Keep us posted on what you find and a photo as well. I am in the same boat for my 94.
Old October 2nd, 2015, 10:09 AM
phatteus
Matthew
97 D90 ST Beluga Black #2074
I didn't try for the industrial look, but if you don't need a CD player these units can be really compact. I also didn't want to mess around removing the factory amp (not sure if yours is still connected?) so I bought an adapter from Crutchfield to keep using that amp under the passenger seat. Here's my pick list:
Pioneer MVH-X560BT
Metra 70-9400 Receiver Wiring Harness
Metra 40-VW12 Antenna Adapter
Kicker 41DSC654 6-1/2" 2-way Speakers
I was fully installed in less than a half hour, Bluetooth streaming and phone work great on this unit.
Old October 2nd, 2015, 10:25 AM
xjahx's Avatar
xjahx
JAH
Any photos of end product? Also, foolish question, but how and where is the mic for the Bluetooth?
Old October 2nd, 2015, 10:26 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I replaced mine with a Jensen Heavy Duty unit, model # JCV1640BT
It has bluetooth, AM/FM & WB, an AUX & USB ports on the front.
I quite happy with it.
JENSEN AM/FM/WB/USB/iPod & iPhone/SiriusXM-Ready/Bluetooth Stereo
Owners manual. https://www.asaelectronics.com/downl...ers_manual.pdf
Old October 2nd, 2015, 10:28 AM
BlackField's Avatar
BlackField
Oscar
D110
This is what I'm running:
JENSEN AM/FM/USB Waterproof Stereo with Bluetooth
Old October 2nd, 2015, 10:30 AM
phatteus
Matthew
I'll be back out to the truck in a couple of weeks and can snag a photo, but I will say that it sits nice and flat in the existing space and the plastic flip cover on the center console goes right over it no problems (i.e. knob doesn't stick up too high etc.)
Seems like you can turn off the disco lights and go with a clean white LED look. The bluetooth is so good though that it reconnects and disconnects without me even thinking so all I really do is turn the volume dial.
------ Follow up post added October 2nd, 2015 11:33 AM ------
Oh, and I didn't install the mic, it would have been a wire that I would have had to run somewhere, but given this is a ST and I have the NRP Exhaust I don't think anyone could hear me if I tried to handsfree in the car.
Old October 2nd, 2015, 11:29 AM
He likes the cars, the cars that go boom.
-Jeff
!!....old skoolz!
Old October 2nd, 2015, 11:30 AM
Chris B
72 + D1 drivetrain =?
Why not get a Mud like console. Then go double din pioneer Avic type with nav etc?
Old October 2nd, 2015, 11:56 AM
61rover's Avatar
61rover
John Crouse
This seems like a very workable option. I'm considering it as well.
Old October 2nd, 2015, 12:03 PM
phatteus
Matthew
If you go Jensen (looks kinds close to the original deck which is cool), I don't see that they have the Amp control for the factory amp (I could be wrong but didn't see it in the manual). And if you bypass the factory amp, make sure you find the thread that talks about how to do that so that you don't have a problem with your OBD port.
Old October 2nd, 2015, 12:16 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Can you provide a more detailed explanation of how the neutering or removal of the the factory amp effects the OBDII port ?
Would this effect an emissions test, for those who under go an exam?
Old October 2nd, 2015, 12:27 PM
phatteus
Matthew
This was the post that mentioned the OBD and factory amp:
http://www.defendersource.com/forum/...tml#post313322
And here was the pinout for the original 97 wiring that I found really helpful:
http://www.defendersource.com/forum/...tml#post261915
Old October 2nd, 2015, 03:10 PM
dendrite's Avatar
dendrite
97/D90 #147
Thanks for the quick responses! I'm so bling adverse when it comes to such a utilitarian vehicle.
PM RijOsho. He is our resident stereo expert. He likes the cars, the cars that go boom.
-Jeff
Like when you don't see that speed bump?
Pioneer MVH-X560BT
Wow, I couldn't even get it out of the package that fast! I didn't even know there was an amp. Certainly not in the battery compartment. Looks like some reconnaissance is needed.
That looks promising as well
Originally Posted by BlackField View Post
Even more promising!
OKAY, what is a MUD console? May be going in the opposite direction with a double din unit.
Old October 2nd, 2015, 03:36 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
One other thing I did was install a Hirsmann antenna & a switch to retract it when I head into the brush.
When you power up the radio the antenna goes up. It will fit in the stock antenna hole with a little wrangling.
The switch (mounted next to the headlamp dimmer switch) is to interrupt the + to make it retract. This also allows you to keep the bluetooth streaming your music while running in the brush.
http://www.autohausaz.com/search/pro...FUVffgodEwIM-A
Old July 25th, 2016, 07:34 AM
sam t
sam talsma
none
Wondering if anyone ever went with the Jensen Heavy Duty mentioned above. I'm looking for an iPod compatible radio with USB/aux/bluetooth. Also any other tips/hints on swapping the old radio out? Is it plug and play or lots of re-wiring necessary?
Old July 25th, 2016, 11:27 AM
phatteus
Matthew
Buying this harness from Crutchfield at least gave me the right connector, but I did need to add a couple more wires to the harness to get it connected and controlling the factory Amp. It doesn't come with extra wires, but if you ordered 2 connectors you'd have enough extra wires. I also needed an adapter for the antenna, After I had a harness with the correct wires going to places, it was ahem, plug and play. I really do like the Pioneer unit, the bluetooth is great, it instantly connects and when I get back to the car with my phone it reconnects right where I left off. I sadly have some very expensive cars that can't manage that simple feat. I still owe a picture to this thread, sorry about that, will try next weekend...
Old July 25th, 2016, 11:54 AM
sirjond's Avatar
sirjond
Jonny
1995 D90 ST Alpine White
Go Fusion Marine and never look back.
Waterproof Radio and True Marine Entertainment Solutions | FUSION Entertainment
Old July 25th, 2016, 02:26 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
X2
I have fusion on my boat. Fantastic quality and true marine grade durability.
"Barry is correct!"
Old July 25th, 2016, 02:46 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Fusion's website banner. Sigh. Power boaters have all the fun....
90, 97, d90, nas, radio
'94 NAS Coil choice? Ohms? EnduroPro Defender Technical Discussions 0 July 6th, 2010 10:09 PM
D90 Front bumper/winch choice owen Defender Technical Discussions 16 June 1st, 2007 08:52 PM
color choice for wheels mpodgorski Defender Technical Discussions 25 April 21st, 2005 12:56 PM
General consensus question 4.0 or 4.6 to replace 3.5 draaronr Defender Technical Discussions 18 August 19th, 2004 04:25 PM
Now HERE are some CHOICE Wheel Rims wicks Misc. Chit-Chat 6 May 20th, 2004 12:05 AM
