Need a new quality Tubing cutter - Defender Source
Old August 7th, 2011, 10:41 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Re doing my brake and fuel lines and in the past have bought 3 different cheap tubing cutters most blades dull out right way, so I'm looking for a new high quality cutter, came across this automatic ratcheting version for confined spaces , anyone try one of these or similar ratcheting cutters ? Or can recommend a good quality one ? (with high quality replaceable blades ).
http://www.ratch-cut.net/products_RCA.html
Chris "V"
Old August 7th, 2011, 10:57 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
That's pretty sweet but I have used just regular tubing cutter from lowes and such for years. trick is to go in small increments forward and backwards.
Old August 7th, 2011, 11:11 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Most tubing cutters are sold with cheap cutting wheels since the majority are use with soft copper tubing. Rigid, the one you provided the link for, and Snap-on offer a HSS replacement blade for their cutters. I actually think Ratch-cut supplies Snap-ons cutter. One thing nice about Rigid is that it is commonly found and they have a wide roller model which doesn't mar the tubing as much.
Old August 7th, 2011, 07:23 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've used a Ridgid model 103 for a long time, no issues. As said, take it slow.
http://www.ridgid.com/Tools/Midget-T...s/EN/index.htm
If you're really worried about dulling cutters Ridgid makes one for stainless steel, Model 35S.
http://www.ridgid.com/Tools/35S-Tubi...r/EN/index.htm
Several Ridgid cutters you can get wheels for cutting stainless. Here's the chart.
http://www.ridgid.com/ASSETS/B1AB2ED...ent_Wheels.pdf
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 7th, 2011, 09:35 PM
Chris Velardi
Chris Velardi
1975 101FC
Just tried to buy one of the many ridged ones at home depot , none had a steel line application (copper , aluminum and PVC only) and no replacement wheels available there for the SS they even had a ratcheting one that I would have bought if they had the stainless steel replacement wheels .
Chris "V"
Old August 7th, 2011, 11:00 PM
Antichrist's Avatar
Antichrist
Tom Rowe
If you really want one for SS (though I don't really think it's needed) try a proper plumbing supply shop, or order it online.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 7th, 2011, 11:39 PM
Chris Velardi
Chris Velardi
1975 101FC
What I would really like to find is a decent price on a Ratch-Cut 375-A has automatic tension on the cutting wheel and it is ratcheting .
Chris "V"
Old August 8th, 2011, 09:59 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I 2nd the plumber's store. The big hardware stores are not going to have anything above the cutters used for copper,pvc,and aluminum. Try calling the "industry stores" in your area for what you are looking for.
Old August 8th, 2011, 10:40 AM
kevkon's Avatar
kevkon
kevin
http://www.amazon.com/Ratch-Cut-RC37...2814381&sr=8-1
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
WTB Quality used winch 5-6-7,000 lbs MJager Wanted 0 April 4th, 2009 11:12 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
Quality repair in DC area? obrienjb Defender Technical Discussions 2 June 28th, 2005 03:17 PM
Looking for a quality used Engines... h2eater Defender Technical Discussions 6 August 8th, 2004 12:27 PM
