Need a D90 SME - GVWR, GCWR, Towing capabilities... - Defender Source
Old August 17th, 2012, 08:23 AM
snosrfr's Avatar
snosrfr
Chuck
95 D90
I've exhausted searches on our site and the interwebs... what i am looking for is the foremost SME (subject matter expert) regarding towing capabilities, limitations, and the extensive dynamics involved with the NAS D90.
Goal: I need to understand what i need to do to ensure that my mod'd D90 will be able to pull an Airstream (22', 2500lb). She already has a built up suspension system (xheavy springs, 3-link, etc...) looking for power plant/drivetrain advice.
* yes, i understand that a D90 is far from the ideal tow vehicle for this application. but like my husky, she's been loyal to me, and i am/will remain so to her...
"hate is a special kind of love we have for people that suck."
Old August 17th, 2012, 08:32 AM
The 90 will tow 5000 pounds with the factory hitch, but the short wheel base and the 3 link may make it squirily.
Old August 17th, 2012, 11:39 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I have towed a Pop-up with mine, R380 300 Tdi, with out a problem. But the trailer does want to push the truck under braking. If you do not have brakes on the airstream yo may not like the towing of it in the D90.
Land Rover 110
Old August 17th, 2012, 01:54 PM
you modified it ... all bets are off!
Old August 18th, 2012, 03:06 PM
snosrfr's Avatar
snosrfr
Chuck
95 D90
Scott,
yeah - class III heavy duty tow set up. I am concerned about the loose 3-link rear end but do have a sway bar that will help with that...
Mike,
that is good to hear. what's the overall weight of your pop-up? I am going to go with a tandem axle model (also reduces tongue weight) and will definitely have brakes on both. I'm just now starting to research different trailer break systems (any advice?).
does anyone have any advice regarding either aftermarket rotors/pads, or powerplant options (definitely leaning towards a diesel)?
thanks,
-Chuck
Old August 18th, 2012, 04:17 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
If you are keeping it rover go with the V8 or the TD5.
Not sure I would tow with a 3 link but then again I am a wus and do not think I would tow that much with a 90 even with stock suspension.
Need trailer brakes for sure
Old August 19th, 2012, 09:54 PM
snosrfr's Avatar
snosrfr
Chuck
95 D90
i come up w/ very little when trying to find detailed threads re: successful diesel conversion applications for 90's...
i'm looking to get the greatest increase in low-end power while hedging the negatives (extensive mod's to drivetrain etc). I'm not overly concerned about the additional weight, it will actually improve steering/handling due to the 3000lbs i will be towing.
Old August 19th, 2012, 11:02 PM
snosrfr's Avatar
snosrfr
Chuck
95 D90
i do believe i've found a proper solution (well, to the powerplant piece...)
http://www.ecologicalvehiclesolution...A_4BT_D90.html
just emailed Shane...
Name:	Screen Shot 2012-08-19 at 8.59.43 PM.png
Old August 19th, 2012, 11:32 PM
aka rover's Avatar
aka rover
ed angel
95 D90
That is pretty darn cool!
85 D110 3.5 3 DR
Old August 20th, 2012, 01:25 AM
snosrfr's Avatar
snosrfr
Chuck
95 D90
...and here is a write-up the owner (Holt Webb) did for 'Land Rover Monthly' on the conversion.
http://holtwebb.blogspot.com/search/label/d90
expensive but very well done!
90, d90, wing
Multiple D90 Parts discojosh2000 For Sale - Parts 13 November 2nd, 2010 07:35 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
