Need a Borg Warner T case expert... - Defender Source
Old April 11th, 2016, 11:52 PM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
I recently started getting vibrations and grinding noise while feathering the gas on my 92 RRC. I decided to replace the T case output shaft bearings as i noticed a little play. When i pulled out the rear bearing housing (after way too much effort) i end up with this.
Has anybody experienced this? How do i get the shaft out now...? What could possibly be holding it in there...?
Thank you for any help.
-Gabe.
Old April 12th, 2016, 02:28 AM
Get a LT230. At least as a back up spare.
Old April 12th, 2016, 07:40 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
On the LT230 it pulls straigth out. How do i access the snap ring. I got the front dissasembled already. But i cant see anything that might be holding the rear...i have a hard time finding a complete LT230 with everything needed for the swap, so i havent considered it yet...
Old April 12th, 2016, 08:24 AM
A rebuilt BW from Dave Ashcroft is about 1200 plus the shipping so roughly 1500 delivered. If your VC is anywhere near 75K miles, it might be time to consider a new one before that one goes bad. And it will go bad.
Old April 12th, 2016, 08:57 AM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
You bring up a good point here Bill. This repair doesn't seem like it's talked about often. Is the only way to know the VC has failed is no 4x4? I've seen this bad on a truck with 72k recently but ok on a truck with 160k.
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old April 12th, 2016, 10:20 AM
Gabriel_Laconi
Gabriel
1992 Rangge Rover
Disclaimer: 15+ yrs ago when my BW shit the bed I swapped an LT 230 in.
So after looking closer at it, it looks like that snap ring is supposed to hold the output shaft in the output housing. Unbolting the 6 bolts on the output housing is all that should be needed to remove the whole assembly.
-Jeff
I removed the 6 bolts, the shaft staid behind and the only reason the housing came out is because the bearing was removed from the shaft.
FS: 1989-1995 RRC Burled Walnut Borg Warner Transfer Case Knob mpodgorski For Sale - Parts 7 May 17th, 2015 09:25 PM
Borg warner t case from rrc Jwillia For Sale - Parts 1 October 13th, 2014 09:38 AM
RRC 3.9, auto transmission, and borg warner vtrover For Sale - Parts 0 December 7th, 2012 08:36 PM
Borg Warner Transfer Case Shifter Linkage (RRC) cellulararrest Wanted 2 August 22nd, 2007 01:20 PM
BORG WARNER juice rover4x4 Defender Technical Discussions 0 January 20th, 2007 05:26 PM
