Need 95 style AC pictures or instructions - Defender Source
Old June 19th, 2005, 01:53 AM
What are you supposed to do with the original fuse box? what are you suposed to do with the AC fuse box? Are there spacers between the fuse box and where it bolts on to the bulkhead?
Help. Whatever dealer tech installed this thing in 95 should be shot.
Old June 20th, 2005, 12:41 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Ron,
They were no fun to install. I believe there were spacers for the fuse box bracket. I seem to remember having to trim the fuse box cover. I think the A/c fuse panel went into the fuse box...but it's been a long time. I'll see if I saved any install instructions. I assume you are working with the Wynn's or White (I think) kit and not the Diavia? The 14CUX ecu is relocated to the side of the passenger footwell rather than under the evaporator, correct?
Rob
Old June 20th, 2005, 12:12 PM
Roadsiderob
Robert Dassler
1994 D90
Ron,
I checked, I don't have install instructions any more. I do have wiring diagrams. Based on what I see in the wiring diagrams, the early 1994 Diavia system used a separate fuse panel for the A/C which took power off of the alternator. Now that I think about it, I think we mounted those separate fuse/relay panels on the front of the heater box under the hood...don't drill too deep! The Diavia system had parcel shelf mounted A/C controls and the Evaporator case went over the 14CUX ECU. I recommend you move the ECU to the side of the passenger footwell as was done on the later Wynn's kits prior to mounting the evaporator...it will save a lot of pain later if (when) you need to access the ECU. Are the thumbscrews obsolete?
Rob
Old June 20th, 2005, 02:20 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
I have the 95 system.
The fuse box for it is just hanging. The cover is cut. No spacers and the stock fuse box panel seems bent out (but I made it fit and it seems ok). Still need the thumb screw. what I really need is a pic of it properly installed.
Ron
Old June 20th, 2005, 04:46 PM
OK who need to know? Ron or Ron?
Old June 21st, 2005, 01:10 AM
There is some issue with one computer and for some reason it remembers me as ron peppard.
Why I dunno.
Old June 22nd, 2005, 01:15 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Ron,
I have the 95 system in my 94 and am near you. Let me know if you need to look at it in person.
Rich
95, ac
NAS 90 Used AC System early 95 working SafariHP The Vendors Loft 0 October 26th, 2009 08:36 AM
Will AC from a 94 fit a 95? aosias Defender Technical Discussions 1 January 21st, 2009 01:50 PM
seeking Badger gutter install instructions Gkase Defender Technical Discussions 3 February 26th, 2006 12:28 PM
AC Unit from a 95 ST boshea For Sale - Parts 15 August 29th, 2004 11:33 AM
Vents for 94 style AC evilfij Wanted 3 June 3rd, 2004 11:43 PM
