Need 300 TDI/2.8 injector size - Defender Source
Old January 12th, 2015, 11:02 AM
Question Need 300 TDI/2.8 injector size
I'm going to get a diesel injection compression test kit that has injector adapters (in addition to glow plug adapters). I much prefer injector adapters because they don't require removal of the AC compressor to test. Does anyone know the mm size of the injectors?
I have my on on a kit that include LR in it's compatibilities, that include M20, M22 and M24 injector adapters. But not sure if those cover our TDI's or other makes.
Mark Kellgren
KM4BOR
Old January 12th, 2015, 11:37 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Mark:
I've only seen the compression testers that fit into the glow plug hole.
Let us know if you find one that replaces the injector as the long thin TDI glow plugs have a tendency to break off during removal.
RDavisinVA
Old January 12th, 2015, 12:42 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
I think Mark is referring to a compression tester, not a pop.
Mark, You could always give M&D Eng a bell.
Eric.
Old January 14th, 2015, 10:34 AM
update: M&D said to use glow plug (m10x1.0), not injector adapters. there you go
Mark Kellgren
KM4BOR
300 tdi, tdi
300 tdi fuel injector replacement (HOW TO) nathanwind Defender Technical Discussions 35 October 13th, 2017 09:46 AM
300 tdi injectors - high pressure injector option for replacement? nathanwind Defender Technical Discussions 14 July 7th, 2017 03:00 PM
AB Now has 300 Tdi injector pumps brn24whl The Vendors Loft 5 December 21st, 2012 08:45 AM
300 Tdi injector crobinson Wanted 0 September 10th, 2010 10:17 PM
300 tdi injector replacement discotdi Defender Technical Discussions 13 June 24th, 2010 06:24 PM
