need 2 inch longer end links for front Swaybar - Defender Source
Old October 11th, 2016, 02:41 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I did some searching on this and I know there are a few forum members that have made them in the past. I unfortunately have zero metal working skills. I have a 2 inch lift and I'd like to try reattaching my swaybar to see if I can stabilize the truck a bit more on the trail. I know AB or RN sells a 2 inch block that mounts to frame attachment points but I'd much rather keep the bar tucked up higher vs dropping it down and using the stock links
I didn't find anyone that sells a longer end link, but does anyone know of a generic link that could work? I know Currie has custom end links but I have no idea what bolt sizes to use or what length to order etc.
Old October 11th, 2016, 02:52 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Has anyone used something like this before?
https://www.summitracing.com/parts/hel-7961/overview/
Old October 11th, 2016, 03:04 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
On other makes and models. Not much to endlinks as long as they are the proper length and don't bend.
Old October 11th, 2016, 03:07 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
The radius arm front suspension has a lot of roll resistance built in to it (torsional twist across the axle being absorbed by the radius arm bushings).
Could you describe more about the symptom you are looking to reduce?
Should you decide that extending the links is necessary I would just bring them to any local welding shop and ask them to extend by 2 inches.
Old October 12th, 2016, 12:18 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
FYI just by looking you can tell that sway bars on a Defender were an afterthought, and somewhat counterproductive to the benefits of the design.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old October 13th, 2016, 01:08 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
My truck suffers from being incredibly unstable and tippy off road. I have numerous threads about it on Dsource. I'm simply looking to try different setups to see what I can to improve it. I've tried many different radius arm bushings and made tons of adjustments but it's still too tippy. It's tippy sitting still. if I park it on an off camber street, I can visibly see the truck leaning even on the smallest of grades. So static lean like that removes out variables such as shock valving, bushing bind, unretained springs, etc. and basically brings it down to spring rate and anti roll rate. I've swapped springs to no avail so I'd like to try the roll bar again and see how it performs.
To be perfectly straight with you guys.. I can live with the tippiness but I'm a new dad and I've been really really close to rolling the truck many times and i don't want to have that happen with my 11 month old in the car. If I have to sacrifice a little flex for some more stability then I feel it's the appropriate dad thing to do.
Old October 13th, 2016, 01:29 PM
The suspension was designed in the late 60s and no trucks had sway bars until American started buying them twenty years later. It should not be tippy and you should never need sway bars. Especially the later axles like yours with the stupidly stiff radius arm bushings. Sway bars were so people could drive them like a race car on the road without the body roll.
Old October 13th, 2016, 01:32 PM
A sway bar is not going to affect when you roll the truck. The only way I could see that you would be really tippy is if you had a ton of weight on the roof.
Old October 13th, 2016, 01:57 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
It's an SW and has a safarigard roof rack on it. I'm going to try retained rear springs as well to see if that helps but honestly my issue is that it seems to excessively lean on small grades so by the time it really has to articulate over something the body is already leaned over 20% more than it should be and exacerbates the effect.
I have these options as I see it:
1. Try a sway bar which has the same effect as increasing the front spring rate progressively.
2. Swap to a much heavier rear spring to force the front end to compress more.
3. Retain the rear spring at the price of articulation. I have the old Rovertym spring in back and I'm not sure how much they stretch. I doubt anywhere near as much as the cones allow but if that gets me another inch of compression in the front than it might be OK.
Old October 13th, 2016, 02:00 PM
Something else is seriously wrong. Your suspension should not be unloading on side slopes with only a 2" lift.
Old October 13th, 2016, 02:04 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
The truck almost rolls not because I lean it over too far and it flops. I understand a sway bar won't help there. The close calls come from when weight transfers from one side to the other. The body swings over unabated and in some cases has picked the tires off the ground... while taking the exact same line as other defenders, inching myself over obstacles. I've messed with shock valving and tried swapping brands as well. Going to custom valved Fox shocks helped with its on road manners but the effect is still prevalent on the trail.
Old October 13th, 2016, 02:09 PM
Lack of droop issue? Tire off the ground == shocks don't do anything.
If not a lack of droop issue, have you tried running el-cheapo gas charged shocks instead of all this fancy stuff you're running?
Old October 13th, 2016, 02:19 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
to reattach your ARB with a 2 inch left, go to metaldepot.com get your self a 1.5"×2.5"×12" lenght of ally cut it in half drill 4 holes and slap them on.
with your weight transfer you gots a problem, do you have a ton of crap on the top???
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 13th, 2016, 04:33 PM
Seems like Steve doesn't carry much on top. Just some camping stuff:
http://www.defendersource.com/forum/...ail-72825.html
I'm confused about why his truck doesn't have damping when his truck shifts weight. I've seen this before but only when people were running non-gas charged shocks with fairly light compression and rebound damping. Steve's been complaining about this for literally years...I'd love to just inspect his setup and troubleshoot in person.
Old October 13th, 2016, 05:13 PM
roverman2010
1985 LR 90 200Tdi
if you are more incredibly unstable and tippy as this guy, then you gots troubles boyo.
this is the only picture with out a number plate as he knows who he is
but in all honesty I always disconnect my ARB's when wheeling
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old October 13th, 2016, 05:18 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Why all this talk about a front sway bar?
The Rover front end is already pretty stiff. If I hadto guess I'd say a lot of your roll/tippiness is coming from your rear. Put a sway bar out back and make your front end do some work.
Old October 13th, 2016, 05:24 PM
roverman2010
1985 LR 90 200Tdi
if he has a 95 it should have rear ASB as std? he is talking about the front as with a 2inch lift the ASB fouls the track rod with out spacers.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old October 20th, 2016, 01:09 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Appreciate that. Anytime you find yourself on the west coast you're welcome to!
I can't run a sway bar in the back without completely destroying the articulation. Longest I keep it away from off camber situations, the truck works really really well off road and I'd like to keep that. I've seen the threads about the other forum member who rigged up a Currie anti rock bar on his defender but I don't nearly have the metal skills to put that in myself and I just haven't found a fab shop that I would farm the work out to at the moment. I chose the front simply because it has so little flex to begin with (compared to the rear) that the negative effect of the ARB would be minimized on the front axle. That's the only reason.
I think my next move is to replace all the springs (I've mismatched springs over the years but the current set has 10 years on them), increase the rebound valving in the back, and add an ARB where I can. See how that effects it.
Rear Swaybar Quick Disconnect Rugbier Wanted 18 June 24th, 2017 11:47 PM
WTB: Front & Rear Swaybar / ROW 110 ATX_D110 Wanted 4 October 30th, 2015 10:10 AM
Front (and Rear) Swaybar and Hardware.. LRNAD90 Wanted 4 June 22nd, 2015 01:24 PM
Front End rods, bars, links, arms???? tomaco1 Defender Technical Discussions 6 November 25th, 2010 04:41 PM
Wanted: Rear Swaybar links fleabus Wanted 2 February 8th, 2007 04:14 PM
