Navigation install - Defender Source
Old September 4th, 2004, 03:48 AM
Milo's Avatar
Milo
chris glynn
95 yellow D90
Navigation install
I'm putting an in dash nav/dvd in and it says I need to hook up a vehicle speed sensor to cruise control. Has anyone looked into this? If so how can I do it? Thanks
Old September 4th, 2004, 11:25 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Can't help there, but isn't earier just to put Garmin street pilot?
World traveler
Old September 4th, 2004, 12:12 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
As I understand it, a lot of automotive GPS systems use an input from the vehicle's speed sensor to provide dead reckoning if satelite reception is lost if you are going through a tunnel, or surrounded by buildings that block the bulk of the horizon. I believe this includes the street pilot series from Garmin.
They may allow you to run without the speed sensor, if you aren't going to be in bad reception areas that often it shouldn't matter. Check the manual for specifics.
If you want to install a speed sensor on your 95, you should be able to find an aftermarket pickup, that detects a magnet attached to the trucks driveshaft.
Hope that helps, Tom
Old September 4th, 2004, 01:13 PM
Milo's Avatar
Milo
chris glynn
95 yellow D90
Thanks guys, ya yousef its alot easier, but I get really good deals on a kenwood system's and it if its to easy then I have no excuse to hang out with my truck all day. Tom can you recommend one to get?
Old September 4th, 2004, 01:49 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
Not sure where you can pick one up. This company builds them. http://www.magsensors.com/
It looks like they fit on the speedo cable output at the xfer case. You could always use it as an excuse to install a cruise control kit.
Cheers, Tom
Old September 14th, 2004, 02:16 AM
Milo's Avatar
Milo
chris glynn
95 yellow D90
Nav update!!!
just finished installing and works good, I do need to hook up the VSS wire to track properly. Might eventually install in the in-dash compartment, we'll see how this goes. Thanks for the input
ID:	1454   Click image for larger version
COME ON, DO IT, DO IT!
"Maury Finkle, founder of Finkle Fixtures, Biggest Lighting Fixture Company in the Southland."
Old January 26th, 2005, 05:57 PM
SeanD-90
Sean Lee
Nav
Can I ask you how much your system was?
Old January 26th, 2005, 06:14 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Hmm.. interesting setup. Have you noticed any issues with shifting and your hand maybe hitting the LCD?
Chris von C
[/size]
Old January 26th, 2005, 09:17 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
That's sortof why I decided not to put my in-car computer screen in the Tuffy - that, and I wouldn't be able to rotate it left/right because of how the stereo mount is 'sunk' in the Tuffy.
I'm in the process of integrating a 7" in-dash touchscreen with a computer running Linux and (free) DashPC software (http://www.dashpc.com). I'll post pics when I'm done. My only fear is the security, or lack thereof, of the LCD touchscreen being in the dash. I'm still not sure if I'm going to just hookup to my existing hand-held Garmin, or buy a dedicated PCMCIA or CF GPS card. I prototyped the system running from a laptop (cables everywhere) and it was pretty damn cool.
Old January 27th, 2005, 11:57 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I installed a 7" touch screen for my Kenwood GPS, I have it installed in my SW between the fresh air vents. I moved the 3 buttons that controll the rear wiper, wash and defrost to the dash just to the right of the steering wheel. It works out to be a great location, very visable and easy to operate. Having the unit mounted in to tuffy seems like it would tough to look at. You really have to take your eyes off the road to view. I too was concerned about theft so I sprayed the metal frame of the screen a matt black, it blends fairly well into the dash.
Old January 28th, 2005, 12:11 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Can you post some pics dave? Thanks.
DJ
Old January 28th, 2005, 02:10 PM
sheki's Avatar
sheki
David Shechter
Here are a couple of shots. The weather was terrible this morning when I took these, hence them being so dark. I couldn't even get a readable shot of the screen on because it was so dark outside. I'll try and post new/better ones later.
ID:	2383   Click image for larger version
Old January 28th, 2005, 03:12 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
Wow... That looks really sweet.. A nice clean installation.
Old January 28th, 2005, 03:28 PM
You guys are
Old January 28th, 2005, 03:40 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
Hey, I knew a David Shechter as a kid in Pacific Palisades. Are you the same guy?
Very nice install. I've been thinking of doing the same with a carputer.
Insert pithy quote here.
Old January 28th, 2005, 04:00 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I dig it. nicely done. What fascia piece did you use for the relocation of the switches?
Any pros and cons to that project?
Old January 28th, 2005, 05:22 PM
sheki's Avatar
sheki
David Shechter
Thanks guys! It's always nice to be told of a job well done. I used the face that came with truck, I just took the buttons and the plate, cut the dash and relocated it. I left the cover in place to hide the mounting arm and wires for the monitor. I'm in the final stages of building a metal box in the rear to house the DVD navigation unit and other electronics. Read, I grew up in NYC, but it's wild to hear about someone else with the same name.
Old January 28th, 2005, 07:57 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Nice. I'm impressed the the switch relocation. Nice work!
DJ
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Bench seat install in '97 hartop timcd90 Defender Technical Discussions 1 February 15th, 2005 01:57 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
