NAS Value with a New/Rebuilt Engine - Defender Source
Old December 2nd, 2013, 04:32 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
I am recently new to the boards and doing as much reading /research as I can (probably too much) before I purchase my first Defender.
I noticed that are some decent NAS D90's out there with high miles (150K+) that will probably need an engine rebuild or a swap within a year or two.
Do you think the value of an NAS Defender 90 will decrease, hold, or increase due to the installation of newer lower mileage engine? A local dealer near me that deals with many of these Defenders mention in his opinion swapping in a 4.6 would increase the value.
What are your thoughts on this?
Old December 2nd, 2013, 04:53 PM
Where did you get the data point that it will need a new engine?
Frankly if it's made 150k it's been well looked after and will likely make 200k or so ... do you envisage putting 50k miles in a year or 2?
You'll never make back the money you spend on a car ( unless you are a skilled restorer / lucky or playing at the higher end of the collectible scale ) ... that's car ownership 101.
Don't worry about miles, worry about overall condition, maintenance and corrosion.
And you can never do too much research ... but whatever happens a defender will stab you repeatedly in the wallet ... starting on the drive home.
Old December 2nd, 2013, 04:54 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Personal opinion of mine if thinking of resale ease or value, would be to rebuild the original 3.9L engine. Conversions are not mainstream desirable to regular folks I would think, although popular with die-hard LR owners. As far as the value of NAS Defenders increasing , I would venture to say yes as they are reaching collectable and high end status with the added fact that the Defender in it's present form will cease production in 2015. Just my opinion.
Additionally just as least once mentions, the real value lies in the overall condition and maintenance. Engines are easier to rebuild than a complete frame off restoration of body and chassi.
Old December 2nd, 2013, 05:55 PM
Holiday's Avatar
Holiday
Ross Simpson
1995 D90 ST/2006 D3 HSE7
You've received solid advice here. Condition is MUCH more relevant than mileage. However, it's a mistake to look at 150k+ mile vehicles as "high mile". Remember- NAS trucks are between 17 (97') and 20 (94') years old! 150k miles over the course of 20 years equals only 7500 miles/yr. That's half of what is considered "average" annual mileage (15k) by most insurance companies and DMV's.
These trucks are at times- troublesome. Combine that with their inherent impracticality, and you begin to understand why the majority of them have unusually low mileage, despite their age. As pointed out- a high"er" mileage truck proves that it has been both maintained, and used on a more regular basis; both desirable traits for anything short of collector vehicles.
Finally, if you'll run a forum search for "3.9 longevity" threads, you'll find that these engines are capable of running beyond 250k, properly maintained. My 3.9 just surpassed 157k with a healthy compression check on all 8 cylinders.
Good luck in your search…!
Old December 2nd, 2013, 06:23 PM
Daniel1's Avatar
Daniel1
Daniel
1984 D110
Thanks for the advice.
I've seen most cars on the road these days last till about 150k miles with a rebuild or replacement needed so I was assuming these would be the same. Its good to know that these car can last and this information will definitely help in my search.
Old December 2nd, 2013, 06:40 PM
Mine left me stranded for the first (and only) time on the drive home from NC after purchasing it.
Old December 2nd, 2013, 11:05 PM
robertf
Robert F
1995 Discovery
Original configuration is more important than original engine. You can't really tell a 4.6 swap without taking things apart, so that shouldn't hurt anything, and I'd bet that at least a quarter of the NAS 90s out there have already had one replacement block.
Old December 3rd, 2013, 12:04 AM
Data point.. my 95' ST NAS has 127k - original clutch, Original engine, tranny, etc. just about 0% rust (some surface on the drivers side footwell from a drip. None on the frame. Its not stored inside either, just cared for
Going on 19 years old. & averaged 6.6/7k miles/year
Condition is paramount - i'd buy a driven one in great shape.
imho
95' D90 - daily driver..
Old May 21st, 2014, 09:33 AM
just to add.. i chose to rebuild the top end of my 3.9 rather than swap the motor. I'm not so much worried about resale as i am about just doing it the way it was intended. If i had a ROW truck i wouldn't care at all frankly.
Old May 21st, 2014, 06:22 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Actually my D90 was extremely reliable except for one stupid connector (fuel pump connector at the right rear wheel well) that took me awhile to figure out was shorted out. I worried less after I swapped to Mallory dizzy and coil.
Robert Deniro
Old May 26th, 2014, 04:17 PM
jack SF
jack baran
95 ST yellow
my 95 has 262k miles. no smoke, no noises. looks to be original and previous owner said its original engine.
engine, nas
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
