NAS SW Rear Defrost Issue - Defender Source
Old November 24th, 2014, 07:38 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
so, odd question...
when i open the doors and the dome light comes on, the defrost light on the dash lights up.
i can hear intermittent buzzing from the relay when it's on.
if i close the door and the light goes out...so does the light.
if i turn on the light manually with the door closed, the defrost light does not come on
when i hit the momentary switch, the defrost works as it should.
i've checked the connections at the light in the dash, on the momentary defrost switch, and on the door switches.
any thoughts? bad relay causing the issue?
Old November 24th, 2014, 09:18 PM
Originally Posted by sloanfiske View Post
so, odd question... when i open the doors and the dome light comes on, the defrost light on the dash lights up. i can hear intermittent buzzing from the relay when it's on. if i close the door and the light goes out...so does the light. if i turn on the light manually with the door closed, the defrost light does not come on when i hit the momentary switch, the defrost works as it should. i've checked the connections at the light in the dash, on the momentary defrost switch, and on the door switches. any thoughts? bad relay causing the issue?
bad ground somewhere.
Old November 24th, 2014, 09:24 PM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Yep. Kinda figured. God only knows where.
Old November 25th, 2014, 11:40 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Yep. Kinda figured. God only knows where. Thanks
You might check the passenger rear under the trim piece that surrounds the rear most window first. I had a ground pull out there that was causing issues..
Attributed to Shayne...
nas
Rear Defrost Switch, Rear Wiper Switch, and Rear Wipe/Wash Switch bradfordish For Sale - Parts 5 January 26th, 2014 12:30 PM
Relocate Rear wiper / Defrost switch kinetic Defender Technical Discussions 4 February 8th, 2013 07:07 PM
defrost that middle part CDNRover Defender Technical Discussions 10 January 7th, 2012 02:51 PM
Broken Defrost Diverter Cable? Wolf Fabrication Defender Technical Discussions 4 June 26th, 2008 04:15 PM
trailer light and defrost lite won't go out!? chidiesel Defender Technical Discussions 0 February 18th, 2004 03:39 PM
