NAS Starter Heat-shield - Defender Source
Old July 21st, 2013, 08:44 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
As contributing factors of the NY extreme heat recently and having no heat shield, my starter keeps freezing up. The starts go from normal to very weak to fully seized starter. The shield rotted off a few years ago and had planned to rig something.
I know many suggest to run without but this year with the high heat its been exceptionally bad.
Any ideas for shield or is this a sign of new starter in the horizon?
Thanks!!
Old July 21st, 2013, 08:57 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Short of an OEM shield, Thermo-Tec makes a lot of stuff. http://www.thermotec.com/products/14...at-shield.html
I'm not a fan of wrapping things though, because of rust issues, but they also make matting you could attach to a home made bracket.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 21st, 2013, 09:04 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Right, that is one of my options, wrap it..... which I agree not ideal. I have not found any OEM, bought a while back ago but was for different exhaust system. I have Borla system.
Fabricating something similar to OEM might not be to bad to mount and wrap it with thermo tape.....
Old July 21st, 2013, 01:03 PM
Antichrist's Avatar
Antichrist
Tom Rowe
A 'U' shaped piece held to the starter by a band clamp with a piece of sheet metal riveted to the other leg and then the heat reflective material stuck on or riveted to the sheet metal should do the trick.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 21st, 2013, 02:06 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
What I was thinking. Should not be rocket science!
Do you think a new starter would matter?
Old July 21st, 2013, 02:42 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Thought there was a company here and/or in the UK that was making heat shields for rovers?
Old July 21st, 2013, 05:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Could be yours is damaged from heat soak. But maybe a heat shield will do.
If you do replace it, I highly recommend a Denso from britishstarters.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 21st, 2013, 08:32 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Thats the starter that I have lined up..... the heat shield crumbled when I last removed the starter, hard to believe it had been doing any shielding the last few years.
I think time to upgrade & avoid further issues. If I'm going to go through the painful process of removing to attach a shield, I will upgrade it.
As far as I know, they don't make shield that will fit NAS with those headers. They make a larger cone shaped which I think fit ROW or different exhaust configuration.
Old July 21st, 2013, 09:42 PM
lets see if we can get a small bit of stainless steel and make something at the weekend!
Old July 22nd, 2013, 07:44 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I'll order some therm material......
nas, starter
Heat shield part number Surf90 Defender Technical Discussions 3 April 20th, 2013 08:46 AM
Heat shield? and where does it go CDeWan Defender Technical Discussions 7 December 11th, 2012 03:20 PM
Non NAS Winscreen hinges, RRC starter and Fan w/clutch Turbofan For Sale - Parts 0 June 17th, 2010 09:02 PM
NAS 90 fuel tank heat shield jetmech Misc. Chit-Chat 12 April 28th, 2009 03:23 PM
Bendix of a 94 NAS spec starter B-Kerr Wanted 0 April 13th, 2005 10:37 AM
