NAS spec D90 tune resistor help required - Defender Source
Old May 2nd, 2005, 06:33 AM
UKlandyandy
Andy
'86 exmil 90, 3.9efi auto
Hi,
I've fitted a RaRo 3.9efi in my D90 and mounted the AFM/air filter across the bulkhead as per NAS spec vehicles. I've been told that because the flexible pipe between the AFM & plenum chamber is now alot longer than standard RaRo install I need to use a different ECU tune resistor.
Could someone tell me what is fitted to there NAS spec D90. I just need to know the colour of the wires on the resistor link and it's prob found next to the ECU. the resistor is in a clear heat shrink tube.
BTW, UK spec vehicles have green for non-cat and white for cats fitted.
Cheers,
Old May 2nd, 2005, 05:48 PM
Black grey and Black white. It runs in and out of the ECU connecting to nothting else right?
Old May 3rd, 2005, 06:23 AM
UKlandyandy
Andy
Hi Mike,
Will check the ECU plug/socket side colours tonight. The tune resistor will have solid coloured wires.
Cheers,
Andy
Old May 3rd, 2005, 12:09 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I wonder. Using the different size resistor changes the tuning to the different fuel map of other countries versions.
Power/Mileage gain to be had for cheap?
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 3rd, 2005, 12:12 PM
Well I'll have to measure the resistance then all you need to do is swap it with a potentiometer (variable resistor) and you can tune it very easily.
Old May 3rd, 2005, 04:05 PM
Hans's Avatar
Hans
Hans Haase
Didn't you post the chart somewhere recently that showed the different nation resistances for the different tuning curves? maybe rig up a little box with a rotary switch to pop between them.
-Hans
My oil line fix
Old May 4th, 2005, 05:04 AM
UKlandyandy
Andy
Here is the tuning resistor chart :
Red wire, 180 Ohms, Australia, Rest of world.
Green wire, 470 Ohms, UK and Europe - Non Catalyst
Yellow wire, 910 Ohms, Saudi - Non Catalyst
Blue wire, 1800 Ohms - 4.2L setup, Non catalyst (I think & this is what I have been recommended to use)
White wire, 3900 Ohms, USA and Europe - Catalyst
Cheers,
Andy
Old May 4th, 2005, 11:41 AM
Hans's Avatar
Hans
Hans Haase
Thanks, I'll have to give this a further look and see what effect it has.
But don't expect anything too quick, my number of projects is far above the number of me to work on them.
-Hans
My oil line fix
Old May 7th, 2005, 07:05 AM
UKlandyandy
Andy
Hi,
Have made up a new tuning connector with a 1.8k ohm resistor. It does seem to have solved the slight hesitation just off idle and the throttle responce is much more crisp now. Still hunts a bit when standing in traffic for a time in drive but thats not to big an issue.
Cheers,
Andy Daws, '86 ex-MOD 90, V8 auto, 'Gon2Far 3Link'
BADLRC Member
Rover-Landers BC Member
www.550-spyder.co.uk
www.gon2far.co.uk
90, d90, nas
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
uk windshield frame vs. nas d90? steved90 Defender Technical Discussions 3 April 5th, 2005 09:07 AM
Non NAS D90 Hardtop lrnasd90 Wanted 1 April 24th, 2004 12:07 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
