NAS mantec snorkel cap fitment-please help. - Defender Source
Old June 21st, 2014, 08:38 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I've received a new cap for my Mantec Snorkel thanks to a fello D-Source member :-) My question is how am I supposed to attach the cap to the tube? See below...I have rigged it with some plumbing tube from Home Depot and double hose clamp it. It is not very eye appealing. Thanks for the help!
ID:	97186   Click image for larger version
Old June 21st, 2014, 08:46 PM
Glad it showed up in one up damaged piece. I drilled all the way thru and secured mine with a 3 1/2" long bolt and a nylock nut.
Old June 21st, 2014, 08:56 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Absent instructions...ingenuity is the Mother of all fixes...lol. Briggs pointed out that mine was installed incorrectly also. lol...
Old June 21st, 2014, 09:03 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Looks like you need the safari head your up tube is to big for the mushroom head, likes like crap what you have on there now
Name:	safari snorkle.JPG
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old June 21st, 2014, 09:21 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
This is the correct head for the snorkel. Exact one it came with. I lost the original off-roading last year and forgot how it used to attach.
ID:	97194   Click image for larger version
Old June 21st, 2014, 09:25 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Accidentally posted twice..
ID:	97196   Click image for larger version
Old June 21st, 2014, 09:42 PM
roverman2010
1985 LR 90 200Tdi
Ok so you had a Mantec head, does the head you have now have slots cut into the tube as a exhaust pipe?
Mine a rip Mantec so the tubing is a bit smaller, but yours should still have the same type fitting
ID:	97198   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old June 21st, 2014, 10:05 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Yep! I have the slots just like that. I need that clamp! It seems like I'm going to really have to crank down on that thing to bend it small enough to fit on the pipe.
Old June 21st, 2014, 10:56 PM
roverman2010
1985 LR 90 200Tdi
Cut a piece of that sewer pipe coupling into a ring and use that to take up the gap
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old June 21st, 2014, 11:19 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I'll post pics tomorrow when it's done
Old June 22nd, 2014, 04:05 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Being a pain...$10 jap crap clamp from autozone=complete shit. Off to the store to find heavy duty ring clamp like you show in the picture.
Old June 22nd, 2014, 06:05 PM
Grover's Avatar
Grover
You maybe missing the rubber gasket fitted between the tube and the cone.
Old June 24th, 2014, 06:25 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Grover that's it! Finally, however I ended up using a u-bolt and it doesn't look too bad and bent the shit out of the new cap fitting it :-/z Once I trim the remaining threads and put a coat of black paint on the clamp I'll post pics.
Mantec Snorkel needed ASAP please d90boy Wanted 0 November 5th, 2013 10:46 AM
What other snorkel tops will fit a Mantec Snorkel? Manimal Defender Technical Discussions 12 July 4th, 2013 07:05 AM
Mantec or southdown used snorkel cap ron Wanted 4 November 27th, 2010 11:09 AM
NAS D110 Dash Fitment Lesandjes Defender Technical Discussions 8 November 2nd, 2009 11:07 AM
110 tire fitment question evilfij Defender Technical Discussions 12 January 31st, 2007 09:22 PM
