NAS Defrost Trunion - Defender Source
Old December 26th, 2015, 09:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
NAS Defrost Trunion
Converting a '93 NAS110 HVAC system to later NAS style. I am looking for pics of how the defrost diverter cable attaches to a "trunion" noted in the workshop manual.
The NAS110 has flat bar coming up through the lower dash and it appears I may be missing this "trunion" piece.
Semper Fi!
Old December 26th, 2015, 11:23 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
If you are referring to the lower dash you will have to relocate cable. Not 100% sure what you are asking. I am currently converting a 93 dash to a vented dash set up for a Soft top conversion. I am happy to take some pictures for you.
Old December 26th, 2015, 11:36 PM
Wolf Fabrication
Sterling Archer
'08 D3
I am asking what exactly does the the new/NAS defrost cable attach to. It's clearly different than the '93 NAS HVAC setup.
Semper Fi!
Old December 26th, 2015, 11:43 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
So you using a later NAS heater box? And keeping your original dash set up?
Old December 26th, 2015, 11:49 PM
Wolf Fabrication
Sterling Archer
'08 D3
No, NAS110 dash is gone and I have installed the normal 94-97 dash pieces and heater box. The only cable I can't figure out is the defrost diverter - where it attaches in/under the dash.
Semper Fi!
Old December 27th, 2015, 12:06 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Ok, gotcha!!! You have to relocate it by drilling another hole in the lower dash. I hope your dash is still disassembled. The lower vent control is mounted in a different location on the 93 for the air diverted. You will need to modify the diverted lever to make it work. I'll go take a pic of what you need. Crap, never mind the dash at the house doesn't have the pc that I am referring to. Sorry, I can take a pic on Monday at the shop but that probably doesn't help you. The one key is to drill the hole big enough for the cable to go through but small enough not to let the cable housing pass through.
NAS SW Rear Defrost Issue sloanfiske Defender Technical Discussions 3 November 25th, 2014 11:40 AM
Relocate Rear wiper / Defrost switch kinetic Defender Technical Discussions 4 February 8th, 2013 07:07 PM
defrost that middle part CDNRover Defender Technical Discussions 10 January 7th, 2012 02:51 PM
Broken Defrost Diverter Cable? Wolf Fabrication Defender Technical Discussions 4 June 26th, 2008 04:15 PM
trailer light and defrost lite won't go out!? chidiesel Defender Technical Discussions 0 February 18th, 2004 03:39 PM
