NAS defender upgrades - Defender Source
Old March 17th, 2015, 05:16 PM
Rajiv365
Rajiv Malhotra
05 LR3
Hey guys
I've been looking for a defender for some time. I've dabbled/flirted with the import route, the 97 sw route and the soft top route. I think I have a deal cooking for a soft top. Curious what upgrades or mods you guys would do? I have an LR3 and wheel it intermittantly, mostly mud/ruts and snow. It's a bit scratched up so probably a fair to moderate amount of wheeling.
For the defender, thinking of a short lift, more aggressive tires, winch bumper and changing lights to LED if possible. Any other thoughts or recommendations?
Raj
2005 LR3 SE, Tonga Green, Johnson Rods, Nitto's
2008 RRS HSE, Silver
2013 Audi RS5 Daytona Gray
1996 Ferrari F355 Berlinetta Rossa Corsa
1995 Defender 90 Soft Top AA Yellow
Old March 17th, 2015, 05:32 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Earplugs, or a stereo with amp and a powered subwoofer.
Battery quick disconnect, tool kit, quick connectors up front for your winch so you can unplug it and plug jumper cables in when needed.
If you are not doing led headlights then install headlamp relays.
Old March 17th, 2015, 05:39 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Congrats on your future 90. I would say your first line of protection should be for rust and oil cooler lines, along with regular maintenance items for a D90, then think about the other stuff
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old March 17th, 2015, 06:28 PM
rovertrader's Avatar
rovertrader
Dale
shop manual
Old March 17th, 2015, 07:20 PM
Join ROAV and/or another Land Rover enthusiast club. Go to events and get to know people. Ask them questions. A defender is not much different in suspension and powertrain from a Range Rover Classic (RRC) or Discovery I.
And make some popcorn, get on youtube, and start watching Land Rover Toolbox Videos.
Mark Kellgren
KM4BOR
Old March 17th, 2015, 07:32 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Lots O' spare time...
Attributed to Shayne...
Old March 17th, 2015, 08:01 PM
Just drive it and see how it treats you. If it's leaving you with cash burning a hole in your pocket, I'm sure you'll have not trouble identifying the things you'd like to change. But I don't recommend making changes before you have lived with it.
Oil coiler lines are definitely something you should assess before driving it too much, but you should also give it a once over in general and check all fluids. I don't consider these changes though, but rather maintenance.
Originally Posted by pendy
I'm here for the D's
Old March 17th, 2015, 08:05 PM
New oil cooler lines. Seriously. -Jeff
It's a 97. I thought 97's had a different layout?
Old March 17th, 2015, 08:53 PM
phoenix37's Avatar
phoenix37
john
keep all your stock parts… if you ever decide to sell you will want to put them back on.. your accessories won't add additional value and sometimes hurt resale depending on how extreme you go with your mods.
Old March 18th, 2015, 11:09 AM
Rajiv365
Rajiv Malhotra
05 LR3
great idea with the quick connect. What are headlamp relays?
------ Follow up post added March 18th, 2015 11:10 AM ------
Its a 95, so the general consensus in addition to what I was thinking is stainless steel oil cooler lines.
Old March 18th, 2015, 11:22 AM
rankar's Avatar
rankar
on our defenders, full voltage for the headlamps go straight through the headlamp stalk switch on your steering column. that's why they burn out occasionally.
so if you're putting in higher wattage bulbs (you don't have to do this relay upgrade if you're going with LED headlamps since the draw is lower), then you need to put relays in that'll switch the power to the headlamps through the relays and not your steering column switch. For example:
Expedition Exchange Incorporated :: Defender :: ARB Heavy-Duty Wiring Loom (M002)
That ARB kit is literally plug and play. For a complete beginner, maybe 15 minutes to change out. Just follow the easy instructions and then you'll be able to use virtually any wattage headlamps (including the offroad 80W/100W bulbs).
------ Follow up post added March 18th, 2015 11:24 AM ------
here's my thread on my winch upgrade. check it out towards the end and you can see the source for my quick connects for the winch and how they look when i spliced them onto jumper cables.
http://www.defendersource.com/forum/...hts-55150.html
Old March 18th, 2015, 11:26 AM
As others have said, drive it as is, do the major stuff mechanically that needs to be done, spend the money to bring it up to a standard with yourself or your trusty Rover mechanic, and upgrade from there.
defender, nas
FS 1993 NAS D110 #401 well-maintained, upgrades PSportoVeloce For Sale - Vehicles 13 June 4th, 2010 06:34 PM
1995 NAS D90 ST Red some upgrades ECR For Sale - Vehicles 13 January 24th, 2010 06:42 PM
1993 DEFENDER 110. $30k IN UPGRADES. LOW MILES. MUST SELL coryp22 For Sale - Vehicles 19 June 26th, 2009 04:02 PM
D90 Suspension Upgrades? Inkopah_D90 Defender Technical Discussions 6 June 16th, 2004 07:12 PM
original 94 tires- upgrades coming jstrong98 Defender Technical Discussions 3 June 11th, 2004 11:34 AM
