NAS D90 steering gearbox leak - Defender Source
Old August 17th, 2009, 06:05 PM
My steering gearbox is leaking out of the very front - the part that is very hard to see because it is very close to the breakfast area. Using a mirror I can see what looks like a huge allen key hole. Does anyone know if this can be tightened? The leak is pretty bad.
It's a remanufactured unit if it matters, and I"ve been very happy with it until now.
charles
Old August 17th, 2009, 06:51 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
There are two things at the top. One is a bleed Nipple. And it should be tight. The other is an Allen key that is for adjusting the box. There should be a nut to tighten around the key but unless you need to adjust the box don't move the adjustment skrew.
Try to tighten hoses to the pump and resivior... Worth a shot.
Are you sure it is not leaking from the bottom seals? If so try the Lucas stop leak.
Old August 17th, 2009, 08:09 PM
No not on top. If looking at the vehicle through the front grill with x-ray vision, you'd see the very front of the gearbox. It's about 3 inches round with a ?6? sided indentation in it. It's leaking out of that end.
Old August 18th, 2009, 07:28 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Can you see it on this?
Old August 18th, 2009, 08:18 AM
Unhappy
Time for a box chuckles. For the first time in a year my steering system is holding fluid-been here done this. Reman box (scored @ Crazy Rays) & new pump. Crazy rays gets $40 for a steering box. Is it bad enough to impact your departure for Vermont ?
Old August 18th, 2009, 01:59 PM
It can be tightened. I forget if the crap flies out if you undo it to somehow reseal it though.
Old August 18th, 2009, 05:20 PM
IIRC this was a recent-ish purchase from a place I recommended. I would call them if you haven't already.
Sigh...
charles
Old August 19th, 2009, 09:44 AM
Smarty pants
Yes that's it. Can this be tightened?
No impact on departure other than a quick powerwash to verify the location of the leak, a longing gaze at Janey, and throwing a bottle of ATF and a rag next to the break booster.
90, d90, nas
'97 Nas D90 Sw Le #008/300 Classic Rover For Sale - Vehicles 19 November 28th, 2013 08:53 AM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
uk windshield frame vs. nas d90? steved90 Defender Technical Discussions 3 April 5th, 2005 09:07 AM
'97 D90 external gearbox cooler pipes. kiphartzell Defender Technical Discussions 0 March 29th, 2005 11:51 AM
