NAS D90 gearing and speed - Defender Source
Old June 23rd, 2015, 10:10 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
Ok, this question has probably been asked 100 times (or more) on this site, but I can't seem to find a thread that fully addresses my question.
I just purchased a 1994 ST with the stock 3.9 V8 and a r380 trans.
Can this machine have the gearing reworked to go slightly faster? It cruises along nicely at 55 mph with about 2700 on the tach. It will go faster, but candidly I'm not sure what rpm level that I should stay at/under.
I know, I know, I know...I'm asking a tractor go 65 mph...it would just be really nice if I could make that happen.
If the gearing can be reworked, what does it take to do it, and what's a ballpark $$ figure I should prepare myself for?
Old June 23rd, 2015, 10:15 PM
That is not a gearing issue. It is a power issue. You should be able to do 90. The engine needs work.
Old June 23rd, 2015, 10:30 PM
carlosz's Avatar
carlosz
Carlos
Second that, also are you rolling on stock tires?
3000 rpm at 70 mph is normal... You don't want to go faster than that on a short tall vehicle.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old June 23rd, 2015, 10:38 PM
Wait is this about the truck with the 4" lift?
Old June 23rd, 2015, 10:44 PM
ionfender's Avatar
ionfender
IO
Josh - You are correct. It's more like 3", not 4" as I originally thought.
Tire size is 285/75/16
Old June 23rd, 2015, 10:45 PM
We need an FAQ for road testing defenders. A V8 should pull hard to 80 and start to taper off and drive stable and smooth.
Old June 24th, 2015, 01:37 AM
But it might vibrate you to death depending on how the 3" lift was performed...
Old June 24th, 2015, 06:35 PM
ionfender's Avatar
ionfender
IO
Good point about the vibration at higher speeds. I'm gong to attack the engine/power issue first. Then determine if I want to take the lift down, or back to stock.
I'm going to check the typical tune-up type items, but I don't that is going to explain my power issue.
The engine doesn't display any other issues besides top end speed (55+)...it sounds fine, drives fine. Any thoughts from the group on where to start diagnosing the engine/power issue? (Assume that I know very little about wrenching on engines...because it's true)
Old June 24th, 2015, 06:37 PM
Spark plugs
Ignition wiring
Air filter
Any codes being displayed?
Any indication of a slipping clutch?
Old June 24th, 2015, 06:42 PM
the 285's will throw off your gearing, have you check your speed with a GPS?
Old June 24th, 2015, 07:10 PM
I second Phillips suggestion to verify the speed. I would also check what gearing you have in the diffs - if this thing is lifted, someone might have re-geared with a bias toward off-roading, not highway cruising.
Originally Posted by pendy
I'm here for the D's
Old June 24th, 2015, 07:45 PM
If it is not tuning, it is most likely the timing chain or cam. The chains always stretch and kill power.
Old June 24th, 2015, 08:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ask the last owner if he changed the gearing and for the love of god get rid of the stupid lift.
Old June 24th, 2015, 08:10 PM
It has nothing to do with gearing if he is only doing 55. Maybe the speedo is a bit out, but I'm pretty sure he would know if he was doing 90....
Old June 24th, 2015, 08:11 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I second Red90's input on the timing set. I rebuilt my engine due to poor performance and the only real issue I found was a very worn timing chain (not a fan of nylon timing gears). Its a pain to pull the timing cover, but it could solve your engine performance problem. I put a Kent cam and a Cloyes timing set in and have had no worries.
Angus
Name:	Timing Chain.jpg
Angus
Old June 24th, 2015, 09:04 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Check for a small slit in the large diameter hose between the MAF and the intake manifold.
Old June 25th, 2015, 05:36 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
please sir, go on...
Old June 28th, 2015, 11:13 PM
ionfender's Avatar
ionfender
IO
Guys - thank you for all of the tips/ideas. Very much appreciated!
I spent some time going through the plugs, wires, hose to the MAF, etc. Everything checked out. I did not investigate the timing chain given the time involved in that fix.
I took it back out for a road test and got it up to 65 and 70 mph (still had power to go faster, but not necessary to do so). I was running about 3100 rpm at 65 mph and about 3200 rpm at 70 mph.
Does that seem reasonable? (keep in mind I'm running tires that are 285/75/16)
It seemed ok to me given that in this thread Carlos mentioned 3000 rpm at 70 mph was about normal.
Old June 28th, 2015, 11:29 PM
Are you checking the actual speed by GPS or are you believing the speedometer?
There is a gearing calculator on Ashcroft's site that you can check on.
Old June 28th, 2015, 11:42 PM
ionfender's Avatar
ionfender
IO
Had to work off the speedo today but my GPS was giving me the business. I think I'm pretty close on the speed based on how traffic was traveling and what the prior owner told me about the accuracy of the speedo.
Just got my GPS updated a few minutes ago, so I'm going to drive it again to verify the speed. Thanks for the tip on the Ashcroft site!
90, d90, nas
Best gearing calculator I have found FYI KevinNY Misc. Chit-Chat 2 October 9th, 2007 12:55 PM
Best gearing for 33`s? oldscratchggf Defender Technical Discussions 1 September 15th, 2006 03:28 PM
Tire/ gearing question oldscratchggf Defender Technical Discussions 9 September 2nd, 2006 10:01 PM
Tyres (again!) + a bit of gearing Berty Defender Technical Discussions 11 September 15th, 2004 03:52 AM
Disco Gearing in D-90? OCD90 Misc. Chit-Chat 7 May 28th, 2004 10:26 PM
