NAS D90 gearing and speed - Page 3 - Defender Source
Old July 1st, 2015, 09:55 PM
Any idea if you have lockers of some sort? Would be pretty weird installing 4.75s without lockers and heavy duty half shafts.
Old July 1st, 2015, 10:45 PM
ionfender's Avatar
ionfender
IO
94 NAS D90, #1379 (SOLD)
As it sits today I can't find any sign of a locker system. The two guys that owned it over the last 10 years used the truck as a grocery getter, and didn't put many miles on it. If it had lockers it would have been the first owner that owned from 94-04. He also had to be the person that changed the gearing.
Old July 1st, 2015, 11:12 PM
kewl, it would be easy to determine if the PO installed locking differentials
Old July 2nd, 2015, 07:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Do you have the names of the previous owners?
Check here and see if they listed mods/gearing...Defender Owners - Defender Source
Rent my
Old July 2nd, 2015, 07:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
The test for Lockers is more fun than checking gear ratios. dde1c
Old July 2nd, 2015, 11:48 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
It's going to be easier to get a couple Disco. 3rds from pick n pull and drop them in than it will be to regear.
-Jeff
And make some extra $$ while he is at it. I wouldn't be surprised if it was a 4:75 Detroit truetrac / locker setup from GBR. It would get snapped up quick here.
ionfender - any chance the 3rds/pumpkins are painted dark green?
Old July 2nd, 2015, 01:18 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
...he said with an evil grin....
Rent my
Old July 2nd, 2015, 03:13 PM
1of40's Avatar
1of40
1of40
Beefy one on the left is a 4:11/Detroit GBR product, Right one is a stock open 3:54.
Old July 2nd, 2015, 03:25 PM
down_shift's Avatar
down_shift
Russell
Here is the Truetrac with stock 3:54. The cheesy red paint was a surprise from the diff shop. I didn't ask or want it.
Old July 2nd, 2015, 04:48 PM
ionfender's Avatar
ionfender
IO
Ha! humorous string you guys have going here with your paint comments. and thanks for the pictures.
down_shift - pumpkins are still black...no green in sight.
Briggs - thanks for the idea to pick some from a Disco.
Old July 2nd, 2015, 06:23 PM
ionfender's Avatar
ionfender
IO
Guys - couple quick questions I thought of while i was driving:
-what age range of Discos run the 3.54 I'm looking for?
-any particular/specific gear lube that should be used in the diff. housings once the 3.54 is in?
-IF a PO put in heavy duty half shafts to go along with the 4.75 gears, will the heavy duty half shafts mesh up perfectly with the 3.54?
Old July 2nd, 2015, 06:26 PM
All discos have a 3.54. Any regular gear oil. Yes, the shaft will work with the new gears.
Old July 2nd, 2015, 08:37 PM
down_shift's Avatar
down_shift
Russell
Here is an idea ..... Given your 3-4" lift, slap on a set of Michelin XZL16x9 tires (~36" dia) on some Wolfs. That would solve your low gearing and look great. Someone post an example photo of this setup.
Old July 2nd, 2015, 09:02 PM
ionfender's Avatar
ionfender
IO
down_shift - why didn't mention that right way...we could have skipped this week long charade. kidding. but i like that your coming at this gearing issue from a different angle. and yes, i would also love to see a pic of one rigged up like this.
it is my goal to get this thing regeared and take the lift down. something closer to stock is preferred.
cue the pictures of the 5 inch lift with XZLs
Old July 19th, 2015, 10:58 PM
ionfender's Avatar
ionfender
IO
Guys - Operation Diff. Swap was success. It's cruising like a dream at 65 MPH and my RPMs are right on top of the Ashcroft specs. So much more enjoyable to drive now. Thanks for all your help!!!!!!!
90, d90, nas
Best gearing calculator I have found FYI KevinNY Misc. Chit-Chat 2 October 9th, 2007 12:55 PM
Best gearing for 33`s? oldscratchggf Defender Technical Discussions 1 September 15th, 2006 03:28 PM
Tire/ gearing question oldscratchggf Defender Technical Discussions 9 September 2nd, 2006 10:01 PM
Tyres (again!) + a bit of gearing Berty Defender Technical Discussions 11 September 15th, 2004 03:52 AM
Disco Gearing in D-90? OCD90 Misc. Chit-Chat 7 May 28th, 2004 10:26 PM
