NAS D90 Fuel Capacity - Defender Source
Old June 9th, 2016, 05:46 PM
kelvinite
Kelvin
1997 D90 SW
I'm embarrassed to admit that I did something that I haven't done since I was a starving student and regularly pushed the limits by driving while low on fuel . . . I ran out of gas on the freeway.
After I filled the tank again, I've found that it only took about 13 gallons until full. I even overfilled slightly just to be sure the pump didn't cut off prematurely. Aren't our tanks supposed to be 15.6 gallons?
Old June 9th, 2016, 05:56 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Yup. 15.6~60l
And don't do that again. It'll quickly kill your fuel pump. Ask me how I know ;-)
Squeezed this much in once. The following month I had to drop my tank to replace the pump. Total Pita.
ID:	151423   Click image for larger version
Old June 9th, 2016, 06:28 PM
kelvinite
Kelvin
1997 D90 SW
Can anyone offer an explanation as to why I ran out of fuel at ~13 gallons?
Old June 9th, 2016, 06:35 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Only put 13 in :p. Seriously though is it possible that some water got into the tank?
Old June 9th, 2016, 06:40 PM
doktorno
Chris deZ.
1995 Defender SW
Is it possible that a NAS 90, leaning to the passenger side, would have an air bubble in the top of the tank that would decrease capacity?
Old June 9th, 2016, 06:42 PM
kelvinite
Kelvin
1997 D90 SW
That would mean that I have 2 gallons of water in the tank! Since water is denser than gasoline and the gas line pulls from the bottom of the tank, my truck wouldn't be running if I had that much water in the tank.
Old June 9th, 2016, 06:45 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
That makes sense. To tell you the truth, I just wanted to give a plausible scenario after making a quick smartass comment. Failed 😞
Old June 9th, 2016, 07:09 PM
D90Overkill
David Frank
1995 ST #2615
Yes, but that would be one heck of a pitched fuel stop. Any tank damage perhaps cause by a previous owner? Dents in the tank hidden by a replacement carrier?
I've only been able to squeeze an extra half to three quarters of a gallon doing the rock, roll and wait method to truly top off. Two and a half missing gallons is beyond weird. Maybe you found a VERY generous fuel pump and you got a full load while only paying for 13 gallons! Please tell me where it's located! ;-)
Old June 10th, 2016, 02:15 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Do you typically run to near empty and fill-up almost alway only takes 13gal?
IIRC, I'm usually at 12 gal at a tick below 1/4 tank.
Is your gas gauge working? I typically fill up, reset the odo and watch that ticks to 180 - 190mi... then I fill up, regardless of what gauge reads. One of the 1st things I learned on SD - as my gas gauge sways left & right when truck is in motion.
Old June 10th, 2016, 02:36 AM
kelvinite
Kelvin
1997 D90 SW
I do usually run the tank near empty but I don't rely on it too much since it's not working properly. The low is correct, but it only reads 3/4 full when the tank is actually full. I need to replace the sender/pump unit when I get a chance. I don't think that a faulty sender would cause my tank to have 2.6 gallons less capacity . . . or can it?
I've been predicting my truck's range based on my calculations of about 13mpg mixed freeway/city usage. I was at 168 miles when my car ran out of gas. Those numbers mean that I only had 13 gallons of gas in the tank. And my 13 gallon fill-up at the station corroborates that number.
The only thing I can think of is that one of the previous owners replaced the stock fuel tank with one of a lower capacity -- for more clearance, maybe?
Old June 10th, 2016, 03:07 AM
Without dropping the tank this will be an unsolved mystery ... in the meantime consider one of these and cure gas anxiety.
Old June 10th, 2016, 08:54 AM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Old June 10th, 2016, 09:57 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
15.95 gallons is my PR. Will try to break 16 next fill-up.
Old June 10th, 2016, 10:39 AM
Originally Posted by down_shift View Post
15.95 is my PR. Will try to break 16 next fill-up.
I've hit 18mpg ...
Old June 10th, 2016, 10:45 AM
D90Overkill
David Frank
1995 ST #2615
I've hit 18mpg ...
All down hill?
Old June 10th, 2016, 10:52 AM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
I actually hit 20 once. The winds behind me were strong enough you could actually feel them pushing the 90.
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Old June 10th, 2016, 11:11 AM
I ran out once. In my own town. Generally will only run 120 miles or so between fill ups. Haven't ever seen 18 mpg and its been a while since I've seen 15.
On the flip side, my new DD is averaging 30.5mpg
Old June 10th, 2016, 11:16 AM
Originally Posted by D90Overkill View Post
All down hill?
on a long run ... i cant stress enough the value of timing up the engine on an oscilloscope!
Old June 10th, 2016, 12:27 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
My guess is the gas station pump is miscalibrated and the station is ripping you off.
Old June 10th, 2016, 01:47 PM
Raddy's Avatar
Raddy
David
1997 D90 ST BELUGA BLACK
This, this right here. Is there anyone out there that actually has a working fuel gauge in their D90?
They aren't even all the same kind of inaccurate, on some the needle bounces but has a relative range of somewhat accuracy and that goes F to E. Yet on others its a complete guessing game where just a sticker of a fuel gauge might be more accurate.
As someone with mildly self diagnosed automotive OCD, this is extremely frustrating.
Eh, maybe I just need to grab a beer and throw a couple of fuel cans in the back.
90, ac, d90, fuel, nas
ROW 110 fuel capacity Jackie Treehorn Defender Technical Discussions 15 January 11th, 2012 02:39 PM
D-90 NAS stock towing capacity johndoe007 Defender Technical Discussions 6 October 16th, 2011 09:57 PM
NAS rear hitch capacity jaygoss Defender Technical Discussions 3 January 12th, 2011 03:05 PM
94 d90 oil capacity TexasD-90 Defender Technical Discussions 2 June 19th, 2010 04:06 PM
3.9L recommended fuel and tank capacity? SFD90 Defender Technical Discussions 5 March 1st, 2004 10:16 PM
