NAS D90 Fuel Capacity - Page 2 - Defender Source
Old June 10th, 2016, 02:01 PM
kelvinite
Kelvin
1997 D90 SW
Originally Posted by lithium1330 View Post
Do you typically run to near empty and fill-up almost alway only takes 13gal?
IIRC, I'm usually at 12 gal at a tick below 1/4 tank.
Is your gas gauge working? I typically fill up, reset the odo and watch that ticks to 180 - 190mi... then I fill up, regardless of what gauge reads. One of the 1st things I learned on SD - as my gas gauge sways left & right when truck is in motion.
Using the trip odometer as my guide to when to fill up is second nature to me as a result of riding older motorcycles that don't have fuel gauges (anyone remember those?) but I can see how relying solely on a fuel gauge that's not 100% reliable can be unsettling to some. In my case, the capacity of the tank isn't even what it's supposed to be which is what threw me off. A double system failure. I guess that's why critical life support systems typically have triple redundancy.
Old June 10th, 2016, 02:10 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by down_shift View Post
15.95 gallons is my PR. Will try to break 16 next fill-up.
FINALLY!
Someone who keeps Gas Cubby records.... scares me to look back and see what I've paid for fuel!
$4.179 Russell? ouch...
Rent my
Old June 10th, 2016, 02:23 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
FINALLY! Someone who keeps Gas Cubby records.... scares me to look back and see what I've paid for fuel! $4.179 Russell? ouch... .
Yep. Track it all, even maintenance. Here is the LR3 that lives at the pump. Charles hooked my up w/ Gas Cubby.
ID:	151459   Click image for larger version
Old June 10th, 2016, 03:22 PM
Quietcat22
Kevin
Originally Posted by Craigd View Post
My guess is the gas station pump is miscalibrated and the station is ripping you off.
That's backwards... He only saw 13 gallons going in at pump after running it out of fuel. If the station gave him 15.6 and only charged him for 13, they would be on the wrong end of that deal
Old June 10th, 2016, 04:00 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Nice.
I don't keep maintenance in Gas Cubby because I was tracking 4 vehicles/gas + diesel and that was enough effort.
FWIW, I only run 87 in the 14CUX truck but it's always ethanol free.
Rent my
90, ac, d90, fuel, nas
ROW 110 fuel capacity Jackie Treehorn Defender Technical Discussions 15 January 11th, 2012 02:39 PM
D-90 NAS stock towing capacity johndoe007 Defender Technical Discussions 6 October 16th, 2011 09:57 PM
NAS rear hitch capacity jaygoss Defender Technical Discussions 3 January 12th, 2011 03:05 PM
94 d90 oil capacity TexasD-90 Defender Technical Discussions 2 June 19th, 2010 04:06 PM
3.9L recommended fuel and tank capacity? SFD90 Defender Technical Discussions 5 March 1st, 2004 10:16 PM
