NAS D90 Clutch/Transmission Question - Defender Source
Old October 6th, 2015, 02:52 PM
neilraymondjr
Jed Raymond
1994 NAS D90
I have a '94 D90 with the 5 speed manual transmission (1st owner replaced the original 4 speed before I bought it in '97). Last week the clutch started to feel light (not the typical push back from the spring), and it became progressively more difficult to put it in gear until finally, the clutch pedal lies flat to the floor and the only way I can get it in gear is when the engine is off.
Any thoughts?
Old October 6th, 2015, 02:56 PM
Probably a leak of clutch fluid. Look in the reservoir and see if it is empty. Then look for the leak at the bellhousing drain and below the pedal in the cab.
Old October 6th, 2015, 03:05 PM
Funny how the weather cools, the seals shrink and you know it is fall due to all the failing clutch posts.
On a side note you know it is fall in Arizona when the license plates change colors. I'm starting to see some of John B's driving challenged neighbors making their way south. Next up are the Minnesota plates followed by the Wisconsin plates and then the Canadian geese show up and crap everywhere. It still beats shoveling snow!
Old October 6th, 2015, 03:23 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
yep mine leaked all spring and then did not leak at all much this summer.........
Todd
'95 D90 #2206
'66 109" P/U
Old October 6th, 2015, 03:28 PM
Clutch fluid heaters would fix this issue.
Old October 6th, 2015, 04:06 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Original Transmission in a '94 D-90 should have been a 5-speed as well, but it was the LT-77, later D90's had the R380.
Anyway, definitely sounds like a Clutch Master, search for the threads on the fun that is changing them out..
~Scott T.
'95 D-90 ST - AA Yellow
90, clutch, d90, ht, nas, transmission
searching for engine and transmission.1988 110 3.5V8 and LT85 transmission Edmond Defender Technical Discussions 6 May 20th, 2015 03:23 AM
Transmission/T-Case/Clutch/Pressure Plate bad? naeirie Defender Technical Discussions 3 March 25th, 2013 06:37 PM
Clutch/Transmission Problem mlw911 Defender Technical Discussions 5 August 15th, 2007 08:17 PM
Transmission or Clutch prob?? kiefffff Defender Technical Discussions 4 June 29th, 2006 10:55 PM
'94 clutch and transmission question CDN38 Defender Technical Discussions 4 January 31st, 2006 01:32 PM
