NAS D110 Electrical Issue - Defender Source
Old April 18th, 2012, 04:00 PM
61rover's Avatar
61rover
John Crouse
Here's one for you NAS D110 experts.
I've been trying to fix this for a while and I'm stumped. Left tail light and both left running lights are out. Everything else works. Is there a common connection point? Where should I be looking for a bad ground or connection?
Old April 18th, 2012, 05:15 PM
Those crappy bulb holders love to fail...replaced a couple of them on my truck. May want to swap them out/check connections/etc. DON'T do what I did recently and start pulling apart the dash wiring .
Old April 18th, 2012, 06:20 PM
bjf's Avatar
bjf
barry f
94 ST #395
Remove the rear speaker and giggle the wires. I bet anything it is loose back there.
Old April 18th, 2012, 06:40 PM
It could be the wires. I had all of mine on one side go out and tore the wiring apart in the back end only to find out all 3 bulbs went out! don't overlook the obvious.
Old April 18th, 2012, 06:48 PM
61rover's Avatar
61rover
John Crouse
I have the speaker cover out now. Checking as many connections as I can. No luck yet.
Old April 18th, 2012, 06:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
Is the front fender running light out and the back one or all in the back?
Old April 18th, 2012, 07:16 PM
61rover's Avatar
61rover
John Crouse
Front and rear are both out as is left (red) tail light.
Old April 18th, 2012, 07:30 PM
The easiest way to confirm is with a circuit tester starting at the lamp itself to confirm ign+ and grnd in the bulb socket. if you have it there it's the bulb, if not, then work back with circuit tester to the connections in the rear, then going forward to the switch and fuse bus.
my bet is bulb, socket ground, or rear bullet connector.. most likely a mix of all.
Old April 18th, 2012, 08:55 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Doesn't the same side lights share the same fuse?
Land Rover 110
Old April 18th, 2012, 10:31 PM
61rover's Avatar
61rover
John Crouse
Fuses are good. Went there first.
110, d110, electrical, nas
just drove my first NAS D110 (282/500) norros Misc. Chit-Chat 18 February 11th, 2015 06:02 PM
converting NAS '93 D110 or '07 D110 cosmetic specs rrcowner Defender Technical Discussions 2 March 5th, 2009 07:20 PM
Restoration of 1993 NAS D110 Needed Jon_Winningham Misc. Chit-Chat 21 January 29th, 2008 12:27 PM
Wanted 1993 NAS D110 Jon_Winningham Wanted 1 November 16th, 2006 10:20 AM
D110 Nas rvrsrvc For Sale - Vehicles 15 December 7th, 2005 02:17 PM
