NAS Coil Springs vs. ???? - Defender Source
Old November 21st, 2012, 03:00 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Hi -
A while back I bought a set of "NTO" (New Take Off) coils from Safari Rover/HP to replace the rusty OEM coils on my truck.
I never gave a second thought to whether they were 1:1 replacements or not. So here's the question, attached are pictures of the coils, they have color codes I can't quite figure out. Can anyone either confirm that they will be fine, or explain how they will not before I go through the effort to install them?
One set is coded Green & Yellow, the other is Blue & White. G&Y is thicker than B&W
thanks for the info and help.
ID:	61333   Click image for larger version
Old November 21st, 2012, 03:31 PM
http://www.red90.ca/rovers/springinfo.html
Can you take a full picture of each spring by itself to see the number of coils and spacing?
Not the right one for a Defender
NRC4306 Disco V8 '90-'96 RR '87-'91 Front left (LHD) 16.44" 133lb/in 7.55 coils blue/white
Not a great rear... Maybe not a bad front?
NRC4234 RR LHD Front right 16.20" 170lb/in 7.00 coils green/yellow
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
So according to that chart, I bought the wrong coils. Awesome.
Color Code Part# Rating #-Coils Length Fitment
BLUE/WHITE NRC4306 133lbs 7.55 16.44" L/R-RR-DIS to 96
GREEN/YELLOW NRC4234 170lbs 7 16.20" RR
Old November 21st, 2012, 03:39 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Here are the pictures
ID:	61350   Click image for larger version
Old November 21st, 2012, 03:48 PM
So 9 and 9.5 coils... Who knows... How long are they? Do you have something to measure the coil diameter?
Old November 21st, 2012, 04:00 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Blue/White:
5 7/8" Outer Diameter
4 3/4" Inner Diameter
16 1/2" Tall
Green/Yellow:
6" OD
4 3/4" ID
15 1/2" Tall
Old November 21st, 2012, 09:04 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I'd talk to the vendor and see what they can do about making it right.
Unknown Author
716-898-8153
Old November 22nd, 2012, 11:28 AM
Originally Posted by founD90 View Post
Blue/White:
16 1/2" Tall
Green/Yellow:
6" OD
4 3/4" ID
15 1/2" Tall
Really not sure what they are then. If you have a vernier or caliper and can carefully measure the diameter of the bar used for the springs, I can estimate the spring rates.
Old November 22nd, 2012, 11:32 AM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Thanks for the help John, I think at this point I have enough information/knowledge that says these aren't right to call Stephen at Safari and figure out how to get a better set....I hope.
coil, nas
Rear Springs for NAS D110 61rover Defender Technical Discussions 7 September 10th, 2009 04:46 PM
Rear Coil Springs for 110 Santiago Defender Technical Discussions 6 January 17th, 2008 12:28 PM
LR HD Springs for a NAS 110? R. Kurk Defender Technical Discussions 21 November 18th, 2007 03:02 PM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
