NAS brake noise? - Defender Source
Old December 18th, 2015, 01:46 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
NAS brake noise?
When I hit the brake pedal while driving, there's what sounds like a hissing noise coming from the rear passenger side brakes. To get a better idea of the sound, I took some video. It's definitely more then a hiss. It also sounds like there's a bad bearing. I'm just wondering what to do. I hope that the audio helps.
Old December 18th, 2015, 02:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Are your rotors scored?
Old December 18th, 2015, 02:13 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Zach, I haven't pulled the wheel off yet to inspect it, But i'm thinking that it may be.
Old December 18th, 2015, 02:18 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
LOL- you could've pulled the wheel off and inspected the pads and rotor in less time than it took to set up that fancy video camera and upload!
My guess- worn brake pads
Rent my
Old December 18th, 2015, 04:41 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
very true. Tomorrow i'll pull the wheel off and inspect.
Old December 19th, 2015, 03:17 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Okay, so I pulled the wheels off. The rear rotors look pretty scored. If you run your fingers across them, you can feel slight ridges. Pics of pads and rotor included.
Old December 19th, 2015, 03:35 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
replace both
Old December 19th, 2015, 04:05 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Zach, i'm assuming that you mean both pads and rotors?
Old December 19th, 2015, 05:36 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Exactly... can't really get away with one or the other, unless you have the rotor "turned". Rotors are pretty cheap.
Old December 20th, 2015, 02:13 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
That's what I thought. Is there any major difference between the slotted/drilled rotors and plain rotors?
Old December 20th, 2015, 02:25 PM
Just get plain rotors. Slotted or drilled rotors are a waste of money.
Old December 20th, 2015, 04:49 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks for the advice. While I'm at it, does it make sense to replace the hub bearings?
Old December 20th, 2015, 05:00 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Never hurts. Especially if you have no idea when they were done last.
Old December 20th, 2015, 05:18 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
100%... I often talk people out of the s/d rotors. I always do aftermarket rotors with genuine pads
Old December 20th, 2015, 06:30 PM
My rear brake pads lasted about 12k miles with drilled and slotted rotors. I only bought them because they were half the price of Genuine I just replaced the rears again with new aftermarket callipers and Genuine pads and rotors. I would have gone with aftermarket rotors had they been available immediately.
Old December 21st, 2015, 10:39 AM
D110
Jamie
1955 107
+1 on genuine pads - did all my brakes and tried everything to get my aftermarket pads to stop squealing (anti squeal, shims, copper grease....) in the end swapped them out for genuine and they are as quiet as a church mouse....
Old December 21st, 2015, 10:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
maybe/maybe not- what kind of miles are on the truck?
I just regreased all the original bearings in my RRC LWB last year.
Truck has 180K on it.
Rent my
brake, nas
Is this lifter noise? 95 NAS V8 D90 ymc226 Defender Technical Discussions 2 July 17th, 2014 06:16 PM
Grinding/weird noise 94 Defender NAS triple9music Defender Technical Discussions 10 July 13th, 2012 12:45 AM
Brake Pad Clunking Noise hutch Defender Technical Discussions 33 July 15th, 2011 10:02 PM
Left brake lights work....the right and door brake lights won't? beko35 Defender Technical Discussions 4 June 27th, 2009 02:12 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
