NAS AC wiring question or call it a random wire question - Defender Source
Old May 3rd, 2009, 12:27 AM
bjf's Avatar
bjf
barry f
94 ST #395
I have a broken yellow wire coming through my bulkhead. It is actually a wire housing. There is no wire inside. I found the other end (cut smooth while looking for a wire inside) Anyone know what this is supposed to do? Should I reconnect the pieces?
Also look at the pic of the connectors under the air filter? Should these be plugged into anything?
ID:	19242   Click image for larger version
Old May 3rd, 2009, 07:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
bump
Old May 4th, 2009, 11:42 AM
bjf's Avatar
bjf
barry f
94 ST #395
come on nothing???
Old May 4th, 2009, 03:11 PM
61rover's Avatar
61rover
John Crouse
Yellow Wire
Hi Barry,
It's actually a vacuum line for the heater/AC system. See this thread for an excellent diagram on what each one does.
http://www.defendersource.com/forum/showthrea...&referrerid=433
Old May 4th, 2009, 03:29 PM
bjf's Avatar
bjf
barry f
94 ST #395
can these cables be reconnected with shrink tube? will that work
Old May 5th, 2009, 09:42 AM
bjf's Avatar
bjf
barry f
94 ST #395
anyone want to chime in on this?
Old May 5th, 2009, 09:49 AM
If you get the kind of shrink-tube with adhesive on the inside and then don't over-shrink it then it might work, otherwise I wouldn't consider it a reliable repair. I've never tried to mend one of these before.
Old May 5th, 2009, 09:58 AM
bjf's Avatar
bjf
barry f
94 ST #395
what can i do then? can i buy replacement lines?
ac, nas, wiring
Where does this wire go ? (electrical question) norros Defender Technical Discussions 4 April 20th, 2005 11:45 PM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
