nas 97 d90 abs ecu - Defender Source
Old October 17th, 2010, 11:41 PM
joyride8
Logan Feldman
1997 D90
nas 97 d90 abs ecu
my check engine light keeps coming on due to my abs ecu beinf fried.. is this part a safety device in any way, does it effect the cars perfornmance in anyway , or is it just a way to avoid check engine light from illuminating while off roading..
very expensive part, is it worth replacing?
Old October 18th, 2010, 10:44 AM
D110
Jamie
1955 107
My understanding is that all the abs ecu does is send back a false message saying everything is ok and that it performs no real function outside of that... it seemed that mine wasn't working so I disconnected it for a while and reconnected it about a month later, and after a day the check engine light went off and everything seemed to be working again.
Old October 18th, 2010, 11:33 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
We had "issues" with that on our '97 when I bought it.
As I understand, it's supposed to indicate a fault with the "rough road" sensor.
Since they were doing the work for free, I let the local dealer fuss with it several times.
Ultimately it turned out to be a bad ground that the ECU needed.
I hate to say anything in too loud a voice.....but it's been fine for the past eight years now.
Old October 24th, 2010, 10:51 PM
Jase
Jase
pending
Rough Road Sensors
On this subject......Has anyone ever found a way to eliminate or bypass the wheel sensors? I have a set of HD CVs without tone rings and get a code every so often. Is there a wiring "trick" or resistor that can be added to eliminate pain these sensors ceate.
90, 97, 97 d90, d90, ecu, nas
97 D90 ABS ECU and short harness pendy For Sale - Parts 1 April 15th, 2010 11:33 PM
'97 NAS d-90 ECU - AMR 6430 dmarchand For Sale - Parts 5 December 20th, 2009 08:39 PM
1/USED NAS D90 (95 and 97) round reverse lamp housing-lens - $10.00 NashvilleRover For Sale - Parts 5 October 17th, 2009 09:06 PM
1994 NAS D90 SW in Coniston Green-Automatic Transmission gearco For Sale - Vehicles 1 April 4th, 2006 11:38 PM
1995 D90 NAS Frame, 3.9L V8 & Radiator for sale Barnett Childress For Sale - Parts 10 June 22nd, 2005 07:38 PM
