NAS 90 ST dome light fitting issues - Defender Source
Old October 2nd, 2013, 09:47 PM
KKilo23's Avatar
KKilo23
Kenny
I am trying to replace my ST dome light (AFU4092L) with a LR original part and I can't get the light to fit properly. Looking at the new unit it looks like the end of the light unit should pop in by pushing in the tab on the end (see picture). It appears as if the tab on my unit is completely solid and won't "press in." Can someone please check their ST light unit and see if I possibly received a defective part. I don't want to force the light into the slot, I believe the upper dash trim is NLA.
ID:	81416   Click image for larger version
ID:	81418   Click image for larger version
ID:	81420   Click image for larger version
Old October 2nd, 2013, 10:10 PM
Ferniekids
Piers
1994 NAS 90 ST
Just "fixed" mine with large amounts of epoxy. One side has a solid and fixed tab, which you insert first, the other has a flex tab that allows it to be inserted and snap in behind frame to hold tight.
Hope this helps.
Old October 2nd, 2013, 10:21 PM
KKilo23's Avatar
KKilo23
Kenny
Originally Posted by Ferniekids View Post
Just "fixed" mine with large amounts of epoxy. One side has a solid and fixed tab, which you insert first, the other has a flex tab that allows it to be inserted and snap in behind frame to hold tight. Hope this helps.
Exactly what I was looking for. Appears my unit has solid/fixed tab on both ends. Neither flex, therefore not allowing the unit to pop in. I will have to call Rovers North for a replacement.
Old October 3rd, 2013, 12:55 PM
lrna04's Avatar
lrna04
Michael
1994 D90
only the middel part of the tab deflects. Just remove the sun visors and trim to see the details of the matting parts.
------ Follow up post added October 3rd, 2013 12:56 PM ------
While you are in there get a replacement LED bulb if you do not have it already...way better
Old October 3rd, 2013, 01:03 PM
KKilo23's Avatar
KKilo23
Kenny
This part where the red arrow is pointing?
Old October 3rd, 2013, 09:34 PM
///Maximus's Avatar
///Maximus
Greg
'94 D90 ST
I just replaced mine with one from RN. I started with the passenger side then pushed the drivers side like heck till it popped in.
ECR NAS 90 cage development questions ECR The Vendors Loft 60 November 5th, 2014 08:20 AM
WTB: NAS 90 ST, white/black/red 05LR3AZ Wanted 2 April 15th, 2013 01:55 PM
Cab Interior Dome Light & Horn AgRover Defender Technical Discussions 1 August 19th, 2012 09:25 PM
WTB NAS Defender 90 ST swing away tire carrier 72rover For Sale - Parts 4 March 4th, 2010 11:03 PM
