NAS 90 Running Lean - Defender Source
Old November 23rd, 2017, 10:35 AM
TRS
Tyler
94 D90 ST #304
NAS 90 Running Lean
Currently having an issue of my 90 running lean and we can't figure what is wrong. Here's a list of things that have been replaced/checked:
- New fuel pump
- New fuel filter
- Computer switched out
- MAF Sensor switched out
- Air leaks checked
- New cats
- New O2 sensors
- Fuel pressure checked
- Injectors seam to all be working the way they should be
- Further it has new plugs, wires, distributor and coil
Open to any further suggestions
Tyler
Old November 23rd, 2017, 10:38 AM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
Fuel temp sensor and second temp sensor on top of manifold behind and to right if thermostat. If it thinks temps are off it will adjust fuel air ratio
------ Follow up post added November 23rd, 2017 10:39 AM ------
If unhooked if will run rich and foul plugs but you can unhook the single bullet connector and see if it improves
'95 RRC CountyLWB - Swapped to a 4.6L, and now working on a 6.0L LQ4
'83 110 HCPU - in "progess"
'90 RRC Truggy - loud and proud, but mostly ugly
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old November 23rd, 2017, 10:45 AM
TRS
Tyler
94 D90 ST #304
Sam,
Thank you for the info! I'll check it out.
Tyler
Old November 23rd, 2017, 12:17 PM
Grover's Avatar
Grover
What makes you think it’s running lean?
Old November 23rd, 2017, 02:19 PM
TRS
Tyler
94 D90 ST #304
Originally Posted by Grover View Post
What makes you think itís running lean?
Started with it running rough, then we hooked it up to the computer. It's running lean on the passenger side and attempts to correct itself on the driver side to the point both sides are running lean.
Sent from my SM-G935V using Tapatalk
Old November 23rd, 2017, 03:13 PM
Grover's Avatar
Grover
What are you using to acquire data, Rovergage?
90, nas
Will a NAS 90 ST ... bjf Misc. Chit-Chat 17 September 2nd, 2011 09:53 AM
90 (NOT NAS) Safety Devices Roll Cage Sale SafariHP The Vendors Loft 1 August 25th, 2011 05:36 PM
'97 NAS Defender 90 ST roll cage and other ST specific components for sale LenB For Sale - Parts 11 August 21st, 2011 09:24 PM
Safety Devices NAS 90 Roof Racks ECR The Vendors Loft 47 September 14th, 2010 09:28 PM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
