NAS 90 Check Engine Light, no codes show - Defender Source
Old February 25th, 2017, 03:20 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
Maybe someone can point me in the right direction. 94 NAS 90 has red check engine light, no codes show on the LED readout. I read one post of someone taking the black cover off to see LEDs? How can I tell the code readout is good, or am I doing something wrong?
Old February 25th, 2017, 03:24 PM
Jason - when you say "red"....you mean the Service Engine light? (not Check Engine)
If that's correct, you need to push a pin/paperclip through the little brown "box" behind the dash to reset it. However, barring that working as a reset - honestly you can just pull the bulb from the cluster itself to avoid the light. It's only a dealer reminder light for the cats to be serviced.
Honestly I'd probably just pull the bulb, that's what I did on mine as I think it popped back on at some point after I reset it initially.
Old February 25th, 2017, 03:34 PM
Jbullis's Avatar
Jbullis
Jason Bullis
Jason- its the Check Engine Light
Old February 25th, 2017, 05:10 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
This is a total shot in the dark (pun intended), but on my 95 D90 the LED readout is so dim that the first time I checked for a code I thought it wasn't working.
Bob Vogler
Recovering Economist
Old February 25th, 2017, 05:20 PM
If you can get to the white plug for the ecu you can clear the code (and show any more in series) otherwise I would disconnect the battery for 5 minutes and let it clear.
------ Follow up post added February 25th, 2017 03:22 PM ------
No code is usually a transient issue (usually 44,45 or 48 which are o2's and the stepper )
95' D90 - daily driver..
Old February 25th, 2017, 05:22 PM
He's done that a couple times (disconnect battery), code keeps popping back up. Talked to him, and he's going to drop the A/C to see if he can get back there and check the connector (he had it down previously and thinks he could have knocked something loose). Also going to try to get him a Rovergauge to troubleshooting as well.
Old February 25th, 2017, 05:50 PM
Jbullis's Avatar
Jbullis
Jason Bullis
I wonder how much this broken wire has to do with the code reader? I held the wire to the point and still couldn't get a read. I just order a working reader off eBay. Let's see if that gets me a code.
Thanks Jason and Rob
Old February 25th, 2017, 05:53 PM
Time for a Rovergauge.
Old February 25th, 2017, 06:10 PM
Jbullis's Avatar
Jbullis
Jason Bullis
Where can I get one?
Old February 25th, 2017, 06:19 PM
Jason I ordered my cable from the U.K. I'll see if I can find the site again and I owe you the service and parts manuals I'll get those to you
------ Follow up post added February 25th, 2017 04:24 PM ------
This is the guy I got mine from
http://www.g33.co.uk/fuel_injection.htm
His email is at the bottom of the page
Huge upload of Doc's in the box invite i sent you
Old March 8th, 2017, 10:30 PM
Jbullis's Avatar
Jbullis
Jason Bullis
Changed the vss unit, replaced the small speedo cable, and switched out the speed gear to the black. I back in business, no light anymore, and speedo looks with 8 mph. Rob, thanks for letting me borrow the rovergauge cable...
90, check engine light, engine, ht, nas
Dang Code 45 Check Engine Light Wolf Fabrication Defender Technical Discussions 27 July 27th, 2012 11:39 AM
check engine light on matansas Defender Technical Discussions 6 April 27th, 2010 02:29 PM
check engine light 41gpaws Defender Technical Discussions 5 December 19th, 2009 05:33 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
