NAS 5th gear/3000rpm surging - Page 2 - Defender Source
Old April 18th, 2016, 09:59 AM
Cross check speed with GPS....and get a beer to celebrate sorting this out
Old April 18th, 2016, 10:51 AM
Originally Posted by evilfij View Post
There is very limited differences between the gear ratios of a 300tdi and a V8 R380 (so it does not matter much) and, if I had to guess, your speedo and tach are off slightly and you have a V8 r380 ratio trans. Oh and the input shafts are different (pretty sure need to check to be 100%) so that also makes me doubt it. Anyway, read the number on the side of the box and you will know what you have. In any event, get the chip (make sure it is the right one), report back.
When rebuilding a box, you can do most things. The V8s have a higher 1st and 5th. These can be mixed and matched, as desired, during a rebuild. If you have a strong TDI, using the lower 1st and the higher 5th gives a wider gear range.
You can use the TDI input shaft on the V8, but it requires a special pilot bushing and clutch.
Old April 26th, 2016, 09:50 PM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
So I ordered a 1990-1994 RRC 3.9L PROM (PRM3652) chip on eBay for $100 from Land Rover Dallas and I swapped it out today.
Followed the directions at:
http://www.v8register.net/FilesRV8WN...UX%20EPROM.pdf
It was easy peasy.
Here's the ECU board once I swapped the chips:
She runs like a champ now. Feels like more changed than just the lack of speed limit (which is confirmed gone). She accelerates all the way up to 70 mph with all the throttle response I need in the first 1/4 of throttle.
Overall very happy with the decision to go with the 4.43 R/P since the only daily driving I do is local streets and not long stretches of highway everyday... Starts from a stop in 2nd gear no prob. Only highway I do is to/from the trails and like I said before, I'm never really in a hurry... At least now I've got that extra 5-10 mph to oomph past a truck on an uphill grade when I need it... And when I don't, at least I'm not bouncing off the speed limiter when I'm cruisin at 65 (89 indicated)
Perhaps a VDO Speedo upgrade is my next project.
Thanks everyone for your help!
Clicking in 4th and 5th gear Cred Defender Technical Discussions 6 August 11th, 2010 04:49 PM
95 D-90 5th gear broken DG Rodgers Defender Technical Discussions 4 February 19th, 2009 10:06 AM
5th Gear Issues bdthornton7 Defender Technical Discussions 0 August 17th, 2008 03:33 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
Weird burning smell in 5th gear? oldscratchggf Defender Technical Discussions 7 February 14th, 2006 09:09 AM
