NAS 110 Won't start after snorkel - Defender Source
Old March 7th, 2015, 10:28 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
I just installed a RN snorkel under the driver side wing, under brake booster, over tranny and up to air box and now it won't start. The engine turns over no problem but just won't start. I checked all the wires on alternator, coil, distributor, under wing, all over...I feel like I must of tweek a connection while I was running the snorkel hose through the engine bay but did not find anything loose. Any thoughts of what else I should check. I also noticed that when I turn the key the tach stays at 0 and doesn't move...is that normal?
Thanks in advance,
NAS 110 V8
Old March 7th, 2015, 10:35 PM
xplorUtah's Avatar
xplorUtah
Andrew P
1960 SII
Wild, wild guess. Does a NAS 110 have an inertia switch?
1960 Series II "Pliny"
1997 D90 SW #2496
"Fear profits man nothing"
1997 D90 SW #2139 Portofino Sold
1995 D90 ST #2445 Beluga Black Sold
1995 RRC SWB Beluga Black Sold
1986 110 200TDI "1 of 1" Sold
Inertia switch should be on the center of the bulkhead. You may have bumped it or knocked a wire loose running the tubing.
Old March 7th, 2015, 10:47 PM
tach reading zero could mean in your fidling you pulled the signal wire on back of alternator.
This def sounds electrical. You missed something..
Mark Kellgren
KM4BOR
Old March 7th, 2015, 11:08 PM
Grover's Avatar
Grover
Check the electrical connections to/from the coil and ignition module/distributor
Old March 7th, 2015, 11:50 PM
the rover shop
shayne young
You've blown the defibulator valve, requires a new engine..I'll give ya $1500 for it and take that mess off your hands..
Old March 7th, 2015, 11:52 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Mike I checked these multiple times.
I will look for the inertia switch. I am not sure what that looks like but hopefully it looks like the one on my DI. I think this may be the culprit. I will report back.
Thanks and keep the suggestions coming.
Old March 7th, 2015, 11:59 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Did you reconnect the MAF?
Old March 8th, 2015, 12:23 AM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Didn't disconnect the MAF. I could not find the inertia switch anywhere. Anyone have a picture showing where it is?
Old March 8th, 2015, 12:28 AM
Step 1 is pull a plug and see if you have spark.
Old March 8th, 2015, 01:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Old March 8th, 2015, 01:49 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
The inertia switch on a 1994 (3.9L) is near the fuses inside the cab. You can see the button on top of the unit. I don't know if the 110 is the same as the 1994 or not but I assume so.
Old March 8th, 2015, 06:04 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
No such luck in fuse area. Does anyone know if the 93 NAS 110 has one at all...mine still has the LT77 not auto.
Old March 8th, 2015, 06:10 PM
Rovertrader has confessed to having a laminated NAS 110 parts manual. You can check with him.
Rudolph Diesel is my damn hero. I don't miss this ignition BS at all.
Mark Kellgren
KM4BOR
Old March 8th, 2015, 06:36 PM
the rover shop
shayne young
Before you go chasing your tail..see if you've got spark...if no spark it's not your inertia switch..
Old March 8th, 2015, 11:23 PM
Rugbier's Avatar
Rugbier
Gustavo
If you have a remote ignition coil my money is you unplugged it while routing the under wing hose
NO SIGNATURE
Old March 9th, 2015, 12:32 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
What? And then remove the rag he put into the hose to keep foreign objects from getting inside the engine?
As people suggested back to basics. See if you have fuel and spark. Works even with EFI.
Did Mantec get around to introducing a snorkel for the Rover V8? Last time I looked (a while back) they only had snorkels designed for the air requirements of a 2.5L engine For a 3.9 it would be restrictive. And since air likes to go down a tube in a straight line your bends might just cause a little turbulence and slow the air flow down.
That's why I got rid of my Mantec and switched to Donaldson air filter system. Filters really well and has plenty of airflow for my engine.
Anyway, as people suggest, first the basics then get out the error decoder to see if the computer can tell you what went wrong.
TeriAnn
Old March 9th, 2015, 12:27 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Found the problem...it was a plug that goes from the coil to right below the disturbutor see plug 1. It has 2 white wires and split loom tubing in pic. It's slightly loose and when the engines is on and you wiggle the wires the engine shuts off. I need to replace that wire connector. Anyone know what that is called?
Thanks everyone for your help in trouble shooting this. I found out after I checked for spark.
Old March 9th, 2015, 12:33 PM
Glad you caught it. Mine was loose on my Classic. A gnat could have landed on it and shut the car down. I just squeezed the contacts together to tighten them up and haven't had a problem since.
That is the plug for your ignition amplifier module.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 9th, 2015, 05:06 PM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Thanks again guys for all your help. I will try to fix that connection later.
Cheers!!
110, nas, nas 110, snorkel, start
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Truck won't start after washing...Please Help!!! jefhuf Defender Technical Discussions 34 July 24th, 2010 12:43 PM
Won't start after short trips 61rover Defender Technical Discussions 7 April 5th, 2009 07:49 AM
Won't Start After CB Install floyd650 Defender Technical Discussions 7 December 8th, 2008 06:18 PM
d90 won't start after pressure washing Bruce Brown Defender Technical Discussions 13 January 23rd, 2007 09:48 AM
