NAS 110 top removal - Defender Source
Old April 29th, 2012, 07:51 PM
NAS 110 top removal
So I was wondering, if I ever wanted to drive around a bit with the top off on my NAS110, would it be as simple as removing the exo cage, then removing the top (and all that goes with it implied) and then remounting the exo cage for safety? Is there anything big I'm missing as steps or parts?
I know what's involved in taking off the exo cage and the hard top, I'm just wondering if there is anything fundamentally unsafe about doing what I described? In the event of a rollover or accident, I would think I'm still relatively safe and that the exo cage would not be structurally compromised.
Old April 29th, 2012, 07:56 PM
The rear door would act like a wind anchor and look pretty dumb!
Old April 29th, 2012, 08:18 PM
yep, that was what I was forgetting about! Thanks. If I ever did that I would need a way to swap an ST tailgate for the interim.
Old April 29th, 2012, 08:27 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
You might have to consider a place to mount the shoulder portion of the seat belt as well.
Old April 29th, 2012, 09:01 PM
Does the exo-cage tie into the T-posts? If not, you'll want to support/brace those too since the middle doors hang off them too. Two piece doors all around would be the way to go if you wanted to do this often (but sounds like a lot of work).
Originally Posted by pendy
I'm here for the D's
Old April 30th, 2012, 10:46 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Yes, at the seatbelt shoulder mount point.
Semper Fi!
Old April 30th, 2012, 01:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Also the windshield is supported by the top. The convertible, rest of world trucks, has a piece of metal that ties in the rear hoop set to it so the windshield is supported at the top. All in all you could make everything work but it would be a extensive job to get it off and then back on again.
Land Rover 110
Old May 2nd, 2012, 02:23 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I drove around like that for a lot of last summer. I had to take the top off to replace the body cappings, and at first just was too lazy to put the top back on. Then I decided it was kind of nice having it off.
One of the big downsides was that I certainly wasn't going to off-road it like that, which meant that I didn't do any off-roading last summer. I was busy with other stuff anyway though. Also, my bulkhead is shot, and when I put the roof back on the driver's door now doesn't stay closed properly. So, something shifted.
You have the advantage of a roll cage to keep things together. With the roof off of mine, it definitely felt a lot less rigid than it does with the roof on.
- Andrew.
1986 110 CSW 200tdi (
Old May 2nd, 2012, 02:27 PM
looks like the family wasn't in a hurry for you to get it back on either!
110, nas, nas 110
'93 NAS 110 ECU for sale... $200 / 3.9L V8 EStocks For Sale - Parts 2 December 4th, 2011 11:15 AM
Safety Devices 110 Wagon and NAS 90 Wagon cages in stock ECR The Vendors Loft 2 March 3rd, 2011 04:22 PM
Wanted: NAS 110 under $30k jessejames4 Wanted 0 December 20th, 2007 10:28 AM
NAS 110 A/C System newfD90 Misc. Chit-Chat 18 September 2nd, 2006 12:21 PM
NAS 110 Interior Pics Request newfD90 Defender Technical Discussions 8 February 2nd, 2006 09:06 PM
